`70 Charger caliper question
#375390
07/14/09 07:04 PM
07/14/09 07:04 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
This may seem like a stupid question, But i`m working on a car that I did not assemble for a brake problem, and to be honest I don`t have alot of pre 71 experience with details. Are the front calipers supposed to be on the front or rear of the spindle, This car is on the rear (like a 69) and can not be right the way it is set up (note bleeder location and hose routing)
My opinion is the knuckles are on the wrong side, unless there is a caliper with a different bleeder and hose inlet (non kelsy/hayes) that i`m not aware of.
Thanks Rick
Re: `70 Charger question
[Re: Blown71X]
#375392
07/14/09 08:44 PM
07/14/09 08:44 PM
340dart4spd
Parts Problem
Parts Problem
Thanks Rick
Looks like you got em backwards...
[Re: 340dart4spd ]
#375394
07/14/09 09:26 PM
07/14/09 09:26 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Yep they are swapped around never gonna get the air out of the upper chamber properly like this! And it is not that the knuckles are on the wrong side it is the calipers are either on the wrong side or you have two right or two left calipers.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: 340dart4spd ]
#375395
08/20/10 11:41 AM
08/20/10 11:41 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I had the ones on my 65 mounted both ways.As long as the bleeders are up they will bleed.I have them mounted to front now.Its been 7 years since I swapped them and I have great brakes.If you have a sway bar they usually mount out the rear.Dosent really matter as long as the bleeders are up.Rocky
Chrysler Firepower
