Milodon Oil Pump 21190 #374717
07/14/09 04:32 AM
07/14/09 04:32 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
I'd like to know is their a preff for installing a oil cooler with a remote filter?
That is should I route the line out from the pump through the cooler then to the filter and back to the pump or rout the line out to the filter then to through the cooler and back to the pump or does it not matter witch goes first?
JoWeTu_6
Re: Milodon Oil Pump 21190 [Re: JoWeTu_6] #374718
07/14/09 04:15 PM
07/14/09 04:15 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
I was thinking of maybe using a accusump in the oiling circuit. Good idea or am I over thinking the setup?
Any ideas fellas
JoWeTu_6
Re: Milodon Oil Pump 21190 [Re: JoWeTu_6] #374719
07/14/09 04:32 PM
07/14/09 04:32 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I don't see that it would make a difference on cooler routing, the accusump should be routed so the oil coming out is not restricted such as going thru the remote filter or cooler. Plumb it [ accusump ] as close to the pump or oil inlet as possible. The accusump will not cool the oil, if anything it will retain heat depending on the hook up.
Re: Milodon Oil Pump 21190 [Re: rowin4] #374720
07/14/09 05:04 PM
07/14/09 05:04 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Thanx rowin4 thats what I hopped the consences would be.
Again thanks for your help.:)
JoWeTu_6
