383 piston L2315F #373635
07/13/09 12:05 AM
07/13/09 12:05 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
what is the compression ratio listed for this piston ?
how does the comp higth compare with a stock say 69 magnum piston ?
is there a websight that has this info ?
thank you !
Re: 383 piston L2315F [Re: calrobb2000] #373636
07/13/09 01:11 PM
07/13/09 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
they are SHORTER than the factory 68-69 piston CH is 1.920 , factory is 1.932 which puts it .003 in the hole on a blueprint deck .
I don't think it has a compression ratio listed but if it did it would be about 8.5 at .015 in the hole.
FYI in case you haven't been paying attention the factory OVERSTATED the compression ratio of the 68-70 , probably them all , at 10.0 compression , the only way to get that is to build to NHRA blueprint if using an open chamber head .
