Easy removal of silicone caulking? #372747
07/11/09 08:02 PM
07/11/09 08:02 PM
Out West
408strokerdart Offline OP
Out West
Does anyone have a solution for removing silicone caluking....like what is used in your race trailer? I am doing some modification work to the inside cabinets of my trailer and there are alot of remnants of silicone that stuck to one surface or the other that I need to remove before putting it back together. I would like to do so without scraping or damaging the aluminum panels....any ideas?
Re: Easy removal of silicone caulking? [Re: 408strokerdart] #372748
07/11/09 08:18 PM
07/11/09 08:18 PM
Summerville, SC
Gierhed Offline
Gierhed  Offline
Summerville, SC
In my experience as a plumber you would usually have to scrape it but, I have a pinstripe removal tool thats like an eraser on a dowel for a drill that would probably wipe it out quick. Also good ole' WD40 does pretty good at loosesning up adhesion for cleanup after the bulk is removed.
Re: Easy removal of silicone caulking? [Re: Gierhed] #372749
07/11/09 08:37 PM
07/11/09 08:37 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
the rubber wheel in a drill will do it no issues.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Easy removal of silicone caulking? [Re: cheapstreetdustr] #372750
07/12/09 11:07 AM
07/12/09 11:07 AM
Out West
Out West
cheapst
Thanks. This is what I had in mind, just didn't know if anyone had first ahnd experience with using one on silicone.
