Page 49 of 167 1 2 47 48 49 50 51 166 167
Re: New Paint job on a budget thread. #37274
08/05/07 04:04 PM
08/05/07 04:04 PM
Virginia
tett Offline
tett  Offline
Virginia
Question... my father has a Nissan Sentra from the 90s that has the paint peeling problem. It's not down to metal so it may be able to be restored with some heavy polishing, but if not... I saw cheap Duplicolor Clearcoat Laquer "ready to spray" at Pep Boys. Would this be compatible with OEM paint if I rolled it on to bring back a shine?
Re: New Paint job on a budget thread. #37275
08/05/07 05:45 PM
08/05/07 05:45 PM
yes Silver they came with VW styled engines in them <in fact if you look at an 80's rabbit and an 80's omni they are almost identical>.
As for the paint fading is it fading or is the clear they used peeling much like it does on the early 90 ford car's/truck? if it's the second one you be better off sanding it down and just repainting it as the clear will keep peeling off and take any new stuff you put on it. not too sure if its faded if you can buff it out though never really dealt with that personally. I figure if you have the time and/or an extra car try your hand at rolling it too see it looks better.
as for my lil project it might be awhile before I can get to it....money is always the one bad spot, but trying to find an omni/horizon without tons of rust is bad in this area now.
Re: New Paint job on a budget thread. #37276
08/05/07 06:17 PM
08/05/07 06:17 PM
Virginia
tett Offline
tett  Offline
Virginia
I believe it's the clear peeling... thanks for the info.
Re: New Paint job on a budget thread. [Re: tett] #37277
08/05/07 09:46 PM
08/05/07 09:46 PM
Well this is paint job on a budget. I know that this is been heavily geared toward rustoleum/tremclad/brightside. I have seen some posts where someone has sprayed the rustoleum through an HVLP gun. I was convinced that I would be rolling the Rustoleum regal red, but I have been farting around re-aligning doors fenders and I still have to get the hood right before I do any sort of painting. Oh I forgot, I also have to make the roof look like it wasn't tap danced on.
I was getting some sanding supplies for the Mustang at a local pep boys, when I saw the Dupli-color paint shop product. Ready to mix Lacquer stuff that Tett mentioned a couple of posts prior. I know all the "pros" are dogging it which is kind of the reason why I'm considering it.
Does anyone have any thoughts on it. I know Lacquer is a short lived shine, but hey some of the nicest muscle cars that I have seen at car shows about 10 or so years back were painted with Lacquer. I'm going to garage it most of the time anyway. Is this something anyone out there has tried. I easily have a week if not longer before I start putting on any sort of paint.
Feel free to throw in your 2 cents.
Re: New Paint job on a budget thread. #37278
08/06/07 02:12 AM
08/06/07 02:12 AM
First I would just like to thank everyone who put the time into this thread. Before I read this a few months ago I was just going to spray bomb my car flat black!
Background: I have owned this car for nearly four years now. The previous owner had cheaply resprayed over the factory paint. Over years of sitting outside in the sun the paint began to peel off and scatches became more severe. It looked terrible! I had some free time and needed to repaint the car on a poor college student budget.
My steps and method I used:
Prepping:
*Sanded entire car with 120 grit sandpaper with random orbital sander, long block sander, and by hand until car was even to the touch. On extremely bad areas i used 50 grit sand paper, then used 120 grit to even it out.
*Next used Bondo fix a rust bubble and any obvious dents. Sprayed the dried Bondo with 3 coats of Rustoleum Automotive spray primer.
*I did a basic job of masking off lights, door handles, trim, and glass instead of removing them.
*Washed entire car with dishsoap and water. Once completely dry, wiped car down with tack cloth.
Painting:
*Thinned Rustoleum Professional Smoke Gray to just slightly thicker than water using 100% Mineral Spirits (not the odorless kind).
*Sprayed car lightly using Black and Decker Pro paint sprayer and wiggly thing attachment. (1st coat was extremely light and careful to avoid and dripping. In a few instances there was slight dripping which could be lightly smudged out, once paint leveled it was nearly unnoticeable.)
*After a night of drying, I wetsanded the car using 400 grit sand paper to remove any orange peel.
*Applied a second coat of paint using same method.
*Let dry another night, wetsanded using 600 grit sand paper to smooth remaining orange peel.
*Applied a third coat of paint extremely thin and fine.
*Another night of drying, then carefully wetsanded the car using 1500 grit sand paper, then 2000 grit sand paper.
After the final wetsanding, I polished the car using Turtle Wax polishing compound and a cheap orbital buffer.
Results were 1000% better than the car looked before. There is some areas where light orange peel is still noticeable and you can tell we messed up in the painting process. But overall I am extremely satisfied with the outcome!
Total Cost: Around 200 dollars (after many trips to the Ace I stopped keeping count of small expenses) including everything mentioned except the Black and Decker paint sprayer, which I got for free in a promotion.
My initial plan was to roller the car, but after I got the sprayer i decided to experiment a little after doing some reading here and on the Honda forum.
After one week the paint is hard and survived a 200 mile road trip with no unobservable issues or flaws. The paint still has a slight paint smell if you put your nose to it, but I suspect that will go away as the paint continues to harden.
Once again, big thanks to those who pioneered the way and gave me the confidence to do this crazy scheme in my driveway!
oh and sorry for any spelling or grammar mistakes, its late lol
Edit* I had planned to show pictures from various stages of the project, but until i re-gain my old knowledge of BB code one finished picture is all i got:
Re: New Paint job on a budget thread. #37279
08/06/07 06:51 AM
08/06/07 06:51 AM
I just re-read the article in hot rod about this process. Has anyone rollered fiberglass?I have a fiberglass hood with a 3 inch cowl I'd like to try.
Re: New Paint job on a budget thread. #37280
08/06/07 12:22 PM
08/06/07 12:22 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Yes... I did it... and others... and our tales have been recounted in various post on preparing and rolling fiberglass hoods etc... It works and it looks great..
Re: New Paint job on a budget thread. [Re: Marq] #37281
08/06/07 07:58 PM
08/06/07 07:58 PM
Just thought I'd post a pic of my 79 MGB I just finished rolling. Six or seven coats of Canvas White Rustoleum. [image]http://st73.startlogic.com/~pokerisb/pics.html[/image]
Re: New Paint job on a budget thread. #37282
08/07/07 12:43 AM
08/07/07 12:43 AM
WA State
Roadster_wa Offline
Roadster_wa  Offline
WA State
I did the vette.... Works great so far.
Now My question:
Has anyone tried the Van Sickle Paint for tractors? I was in Big R and they have a few oranges. I might try the Kubota Orange. I think someone suggested it, but I couldn't find the post. The old Harley orange is pretty close.
Re: New Paint job on a budget thread. [Re: Roadster_wa] #37283
08/07/07 07:43 AM
08/07/07 07:43 AM
Virginia
tett Offline
tett  Offline
Virginia
For the benefit of everyone...
I happened by Stephen Hull's site and posed an inquiry into whether the U.S. had coach paint or something similar. He replied that he had never worked with any, but he provided a link to something that looked similar, even though he couldn't vouch for it. I just offer this as information... I used Rustoleum on my test piece and it worked fine. So I don't suppose we need any new paints, per se, but I would be interested in a good self-leveling paint with long open time just to make it easier and smoother so the wet-sanding goes more smoothly. Here's the link...
http://www.californiapaints.com/products/rustinhibit/lametal.asp
Re: New Paint job on a budget thread. [Re: Roadster_wa] #37284
08/07/07 10:30 AM
08/07/07 10:30 AM
Now My question:
I was the one that suggested Kubota Orange... I've been using Van Sickle for several projects, and I love it. I actually prefer it to Rustoleum...they're both alkyd enamels, and there may not be any major differences between them but after using a couple gallons of Van Sickle I try to stick with it. It's just a personal preference really. I think the Kubota Orange is pretty close to Harley Orange, but maybe a smidge "brighter". Might be as close as you'll find in a pre-mix color though. If you look at their "custom colors" they have a lot of other shades of orange, but the website doesn't say how to order them... Anyway, I've been nothing but impressed with it so far...
Re: New Paint job on a budget thread. #37285
08/08/07 09:22 AM
08/08/07 09:22 AM
i demand more pics....
also i plan on starting my test job this weekend to see if i can get this done... does anyone know if it would be ok to use a electric paint sprayer (used for paiting walls and such) to apply the paint? thanks everyone for all the help
Re: New Paint job on a budget thread. #37286
08/08/07 04:38 PM
08/08/07 04:38 PM
Electric roller, not even necessary. Follow the process as is, time tested and proven to work. No sense trying to re-invent the wheel.
Re: New Paint job on a budget thread. #37287
08/08/07 06:35 PM
08/08/07 06:35 PM
But you did re-invent the wheel
Re: New Paint job on a budget thread. #37288
08/08/07 11:13 PM
08/08/07 11:13 PM
question when mixing the mineral spirits do i mix in paint can or pour both into a seperate container and mix...
also around how many rollers do i need? 1 per coat so they dont dry out or what?
Re: New Paint job on a budget thread. #37289
08/08/07 11:37 PM
08/08/07 11:37 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
You should pour the paint and mineral spirit into a separate container. ONLY mix as much paint as you need to do one coating of the body. On average it takes about 1/3 of a quart of paint to do one layer on a car body. At our local 'Dollar Store'... I was able to buy 4" X 12" paint trays ( made in black plastic ) at 2 for $1. I bought a dozen of those cheapo paint trays and would pour the paint into the tray, add the mineral spirit... and then blend the two together in the tray.
Rollers... figure on one roller per coat. You can go with two rollers per coat IF you are using one to do the actual paint rolling AND the second clean roller for going over the freshly rolled paint to pop bubbles. IF you seal up a roller between coats in an airtight baggie... you might be able to squeek an extra coat or two out of a roller. But since they are so cheap... splurge and don't go scrooge on rollers
Re: New Paint job on a budget thread. [Re: Marq] #37290
08/09/07 12:14 AM
08/09/07 12:14 AM
thanks again... i plan on using ace rust stop safety orange (i think its the same as rustoleum) for my job on the cav. gonna do it one panel at a time, first im going to do the front bumper and rear first (cause its a new body kit so why not) then the side skirts... followed by the body. i might have to paint outside and i live on a gravel driveway (not a good thing) so i might get my friends dads garage.
anything else i need to know... i just bought the 10 pack of shurline rollers 4" on ebay. and am planning on getting the paint sometime this week.
i got some body work to do before i paint the body though... bondo to fill the dents i guess. and sand the whole body down with 320....
sound good?
Re: New Paint job on a budget thread. #37291
08/09/07 02:04 AM
08/09/07 02:04 AM
like a lot of others i have read most of this whole saga. I am here from a jeep site, i am a jeep guy.
my question, I need to be able to drive my jeep while in the process of this paint job. I can stop for a day or 2, but not long enough to do the whole thing start to finish. is that possible?
what would it take different doing it this way?
thanks for the help
catfish
Re: New Paint job on a budget thread. #37292
08/09/07 08:30 AM
08/09/07 08:30 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
The only thing that stalled me when reading this was the mention of the ACE brand anti-rust paint... as I am not sure how successful it has been in this application. Since you haven't bought the ACE paint yet... maybe there is still time for you to source out a supplier for the Tremclad / Rustoleum or some of the other brands of paint where there has been confirmed success ?
I always shudder when I hear products that are touted by shop merchants as being "...just as good as..." or "....its almost the same thing.." hehhehhehhe....
My favorite story in that vain was the time I bought tires at SEARS and the shop guy said... "... their house brand of tires were made by Michelin Tires and they were just as good as the top of the line Michelin's..." What a lie. Within 36 hours of putting those 'knock off' tires on my car the wife lost control of the car accelerating onto the highway. Fortunately no damage done. But she DEMANDED I take those tires back IMMEDIATELY and go get Goodrich or REAL Michelins. I complied.
I wish I could remember which 'brand name' company use to use the advertising phrase
"... Accept no substitutes... "
Re: New Paint job on a budget thread. #37293
08/09/07 08:50 AM
08/09/07 08:50 AM
You can roll and drive at the same time with a few minor considerations. Any saftey related trim that you remove, like side mirrors will make it tough to drive.
I did my car over a 3 month period of on and off painting and I found that what I learned during the first two or three coats, I'd forgotten during the time that lapsed between them and coat 4.
Other than these issues I don't see why you couldn't drive it and paint it at the same time.
