Page 44 of 167 1 2 42 43 44 45 46 166 167
Re: New Paint job on a budget thread. #37174
07/23/07 09:38 PM
07/23/07 09:38 PM
Maine
Blackstone Offline
Blackstone  Offline
Maine
I get better results brushing over the paint extremely lightly and slowly as opposed to hard and fast. I'm just using the weight of the brush itself to pop the bubbles.
You're not getting anywhere near the ripples that I'm getting with this method... what are you using for a tipping brush?
Re: New Paint job on a budget thread. [Re: Blackstone] #37175
07/23/07 10:06 PM
07/23/07 10:06 PM
I'm using the 75 cent 3" wide foam brushes from home depot. I used a new one for every coat. I went through 3 for the sunroof but next I'm going to do the whole roof, trunk lid and hood in one go so I'll get more mileage out of every brush.
Re: New Paint job on a budget thread. #37176
07/24/07 07:24 AM
07/24/07 07:24 AM
Maine
Blackstone Offline
Blackstone  Offline
Maine
Maybe I'll give the foam brush another shot. I don't recall having ripples until I re-used my foam brushes. If I wasn't so cheap, I probably would have mastered this process a month ago.
Re: New Paint job on a budget thread. [Re: Blackstone] #37177
07/24/07 10:13 AM
07/24/07 10:13 AM
Well i haven't posted in awhile life got a little hecktic in the last couple weeks, wife had the baby 6 weeks early, baby and mom are both great and healty!
anyways reguarding the foam rollers from the buck store i have used both and i find no difference between the 2 so i loaded up on the buck store ones since there cheaper and you can get packages of the foam brushes think there is 6 in a pack, at the buck store too. also they have roller tray's 2 for a buck. nothing like really budgeting for this lol
Re: New Paint job on a budget thread. [Re: mopartial] #37178
07/24/07 11:15 AM
07/24/07 11:15 AM
Anybody try this with SS (OMNI) auto paint? It is enamel, dries quick and its already mighty thin.
Go back about 3 pages and see my comments on this...
Re: New Paint job on a budget thread. [Re: mopartial] #37179
07/24/07 08:54 PM
07/24/07 08:54 PM
Sydney, Australia
Down Under Offline
Down Under  Offline
Sydney, Australia
Long time reader and follower of this thread...first post! I am in Sydney, Australia and after looking at the options available re paint, I have decided to give the local Wattyl KillRust Epoxy Gloss Enamel a try (at $19 a litre, I thought it was worth a try). I am currently painting a 1983 Toyota Corona for my son who will soon learn to drive in it. My daily driver is a Ford Fairmont.
Anyway, I am very pleased with the result so far - 4 coats on, wet sanding after the first two (600 grit) , and after the last two (800 & 1000 grit. Just about to go out and do some more wet sanding in preparation for coats 5 and 6. I will be posting photos soon.
Thanks to all for clear instructions and first and foremost to Charger for giving us all this brillant idea!
Re: New Paint job on a budget thread. [Re: Down Under] #37180
07/24/07 09:30 PM
07/24/07 09:30 PM
Put down the first coat on the roof and hood.
Sanded.
Painted
Already has a good shine. Pitty I'll have to sand it away before the next coat.
I was being stingy with the paint and put too much pressure on the roller to squeeze the last drop out of it. I got some orange peel. It was also 85f outside with makes the paint dry faster. All my previous coats were early in the morning around 60-65f. It'll all get knocked down when I sand it before the next coat. Only used 2 table spoons of paint to cover the entire hood. I should have used 3.
Re: New Paint job on a budget thread. [Re: Jolly_Raj_R] #37181
07/24/07 09:58 PM
07/24/07 09:58 PM
here is #566 tremclad sorry it took so long.
this is coat #4 needs to be wet sanded and i might put just 6 coats on and polish it out and see what i get.
this is my practice pannel
Re: New Paint job on a budget thread. #37182
07/25/07 02:17 AM
07/25/07 02:17 AM
venice, ca
admactanium Offline
admactanium  Offline
venice, ca
Well I have to admit, I'm not exactly thrilled with my polishing skills. After the third coat, I gave it another once over with 1000 grit, hand polished with some turtle wax polishing compound and finished it off with carnauba wax. The beautiful gloss of the paint after the third coat is gone, replaced by an endless haze of swirl marks.
if you're going to try to polish out by hand, then you're going to have to sand with progressively finer paper grits. there's no way you can work out 1000 grit sand marks by hand. move on to 1200/1500 -> 2000 -> 2500/3000. there are limits to what you can do by hand. even if you were going to polish out by machine i'd suggest you sand down to at LEAST 1500 grit otherwise you'd be wasting a lot of time and product.
Re: New Paint job on a budget thread. #37183
07/25/07 02:37 AM
07/25/07 02:37 AM
WA State
Roadster_wa Offline
Roadster_wa  Offline
WA State
Painted
The roller marks in this picture could be worked out by running different directions, and not so much pressure. You can put a bit more paint on it and work it longer until just before it gets tacky.
I work the paint more than most pictures I've seen...
When I put a coat on the vette, I must have went over the whole thing 5-7 times each coat, working it different directions until it stopped running and showing lines. You have to work it lightly.
- Just my 2 cents here.
Re: New Paint job on a budget thread. [Re: Roadster_wa] #37184
07/25/07 03:02 AM
07/25/07 03:02 AM
Edgerton WI
Donny O. Offline
Donny O.  Offline
Edgerton WI
Painted
http://farm2.static.flickr.com/1117/890683462_186bc2be47_o.jpg
I totaly agree. i never had lines or marks like that....my coats were transparent but always very even. I went over it and over it spreading it around and evening it out. remember this is the cheap solution not the mirical paint job in a minute job.
BTW i have about 8 coats on my sidecar now but only pics up to the 6th or so. I can still see through it in spots so a few more coats in the works when i get free time again!! here is my pictures of progress.
http://rides.webshots.com/album/559630508GUGsFC
Re: New Paint job on a budget thread. [Re: Blackstone] #37185
07/25/07 09:08 AM
07/25/07 09:08 AM
CAN ANYONE TELL ME WHY THERE ARE SO MANY POSTS THAT SAY STAY AWAY FROM REDS?
Re: New Paint job on a budget thread. #37186
07/25/07 10:09 AM
07/25/07 10:09 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
I don't think anyone has said to avoid red.
We have agreed to stay away from aluminum paints - because they just don't work.
The only problem with the Brightside and the Tremclad/Rustoleum 'Fire Red' is that it might be too orangey red for some people. It is not a deep blood red color and there is nothing you can do to tint it darker.
Possibly there is a difference between the amount of pigment in red compared to the black, white or blues. Less pigment in the paint means it takes an extra coat of paint to achieve the same level of coverage.
Other than that... I used both the Brightside and the Tremclad/Rustoleum 'Fire Red' and I have no complaints at all about it.
Re: New Paint job on a budget thread. [Re: Marq] #37187
07/25/07 11:43 AM
07/25/07 11:43 AM
I SEE THAT RUSTOLEUM PROFESSIONAL HAS A SAFETY RED THAT LOOKS PRETTY BRIGHT
Re: New Paint job on a budget thread. #37188
07/25/07 01:00 PM
07/25/07 01:00 PM
Lake George
blue195 Offline
blue195  Offline
Lake George
I'm using the Rusto safety red on my D100 and my son's Nissan, and it is VERY red. Almost like a fluorescent in some lighting situations. I love it. My other pickup will get the regal red so I don't have to paint the interior roof panel. It's a close match to factory.
Re: New Paint job on a budget thread. [Re: blue195] #37189
07/25/07 01:34 PM
07/25/07 01:34 PM
im wanting to paint my car, its a red now, but want to use safety orange.
i tried black on a few little pieces and it came out ok.... but thats been long ago.
i used 50% paint thinner, 50% rustoleum...
so what advancements have been made since well 6 months ago? any new tips
thanks all id read through all the thread but over 200 pages in 3-4 different threads... is a little much
Re: New Paint job on a budget thread. [Re: blue195] #37190
07/25/07 04:53 PM
07/25/07 04:53 PM
BLUE195....ANY MORE PICS?
Re: New Paint job on a budget thread. #37191
07/25/07 08:55 PM
07/25/07 08:55 PM
when i stop being too lazy to pull out my polishing stuff again.. ill probably work the rear area a little more its a dap duller then the rest..
ps, anything i should be aware of anything before pulling my doors off to give them extra attention? i havent pulled doors before. (they have the classic inside-bottom rust out crap going)
Re: New Paint job on a budget thread. [Re: Down Under] #37192
07/26/07 02:33 AM
07/26/07 02:33 AM
Sydney, Australia
Down Under Offline
Down Under  Offline
Sydney, Australia
As promised, here is a photo of the 5th coat just finished. Not sure how many more coats I'll put on, but pretty happy with the result so far...
Re: New Paint job on a budget thread. [Re: Down Under] #37193
07/26/07 02:40 AM
07/26/07 02:40 AM
Sydney, Australia
Down Under Offline
Down Under  Offline
Sydney, Australia
Another one. This one shows some streaks on the bonnet, which I intend to remove with some 1000 wet and dry before the next coat.
