Fuel Line Size
#371681
07/10/09 01:00 PM
07/10/09 01:00 PM
Posts: 1,534 Florida
CHRGR69
71 Cuda 383 Eddy 750. I have a new fuel pick-up/sending unit that is 5/16". I'm told I should go with the 3/8" line. Will it work with the 5/16" unit, or am I defeating the purpose of the larger line? Should I change unit and go 3/8"??
Grandma always said I had "hands of gold"!
Re: Fuel Line Size
[Re: Crizila]
#371686
07/11/09 03:48 AM
07/11/09 03:48 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
BTW, there are some guys on this forum that can make over 600 HP with a 5/16" line - - - they said.
John, if I didn't know better I'd think this was directed at me. But then again, how would you know my tubing is undersized?
Re: Fuel Line Size
[Re: Crizila]
#371688
07/11/09 01:24 PM
07/11/09 01:24 PM
Posts: 73 Phoenix Arizona
thebankerstoy
Phoenix Arizona
I've always respected the fact that Chrysler used 5/16" fuel lines on low output big block cars and 3/8" on Hemi's and high output big block Wedge cars. I have a mildly modified 440 in my 66 Coronet 500 that puts out around 400 hp and I run a 3/8" pick-up tube and fuel line all the way up to the carb. For the fuel pump, I run one of the Mopar Performance hi-performance mechanical pumps.(part #P4007039AB) To keep the fuel clean, I have one of the Fram HP1 canister style fuel filters back by the stock reproduction fuel tank and a 3/8" in-line filter up front between the fuel pump and the Holley 750 cfm vacuum secondary carb. I've had zero problems with this set-up for many years. Richard
