It is excellent oil. I started using it the minute it was back on the market years ago and have had great results with it. Almost every customer I have that has used it has convinced at least on or two of their friends to switch over as well.
There were ( probably still are, nature of the beast here) many skeptics and doubters on here when it was brought up in the past. They all thought the hype was all "marketing ploys".I finally gave up arguing about it here, wasnt worth it.
I am here to tell you it is damn good stuff. I always tell people, you will notice the difference when you do your first re-build of an engine that has been using it. ( of course, one that was built correctly in the first place)
Again, in my opinion, you cant go wrong.
