B-body Sail Panel Installation #371574
07/10/09 08:45 AM
07/10/09 08:45 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I purchased new sail panels from Year-one for my 1969 Roadrunner. The new sail panels have a place for "clips" that attache to the sail panel and then to the framework of the sail panel area on the car. There were no clips or a place for clips on the sail panels that I removed (the sail panels I removed did not appear to be O.E.)
Does anyone know where I can get these clips to attach the sail panels?
Re: B-body Sail Panel Installation [Re: Imrare] #371575
07/11/09 12:42 PM
07/11/09 12:42 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
bob,use industrial stregth velcro strips,my new sail panels had the slot for the clip in the wrong place,you can pick up the velcro at any homedepot,it works great looks great and you can remove if you need to. good luck
Re: B-body Sail Panel Installation [Re: meepmeep70] #371576
07/16/09 01:52 PM
07/16/09 01:52 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Hey, the velcro sounds like a great idea, should work fine. Thanks,
Bob
Re: B-body Sail Panel Installation [Re: Imrare] #371577
07/16/09 04:17 PM
07/16/09 04:17 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
They use standard door panel clips
