Quick fuels e-85 conversion kit #371265
07/09/09 06:58 PM
07/09/09 06:58 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
I am thinking about converting to e-85 and have been looking at Quick Fuels kit was wondering if any one has used it any problems do you have to change boosters on a 4500 hp holey what about air bleeds and what size jets are you running
Re: Quick fuels e-85 conversion kit [Re: dbran451] #371266
07/09/09 07:06 PM
07/09/09 07:06 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I wouldnt just get the QF kit, Id do the full conversion. Yes, the boosters should be changed for E85.
Get with Mark Sullens. He posts on e85forums.com under the name DragChevette.
He did converted my 950HP and put his own recipe in it. The carb was a jet change away out of the box.
I had a bog problem with it at first, but finally figured out the motor was too cold, 160-165. Let it warm up to 180 and all was good!!
Here is his website.
http://www.geocities.com/mark_a_sullens/MarkSullensRacing.html?1229755926750
He has converted carbs for several Mopar lately.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Quick fuels e-85 conversion kit [Re: dbran451] #371267
07/09/09 07:12 PM
07/09/09 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt use their kit, I sent my 1050 dom to them
for the change to E-85 plus some added stuff. I'm
at 94 jets front and rear but I forget what the bleeds
are but they are different... I know my boosters are
different... they're green now but cant say if the size
is different.... call them and ask what you need...
they are real helpful
