big block head gasket torque sequence and torque spec #371252
07/09/09 06:45 PM
07/09/09 06:45 PM
metro detroit
turner Offline OP
turner  Offline OP
metro detroit
I was wonderingg if anyone had an illustration of the head bolt torque sequence for a big block mopar, and also what is the proper torque spec. for the bolts. The motor in question is a 68 440 w/906 heads and a 1009 fel-pro head gasket.
Re: big block head gasket torque sequence and torque spec [Re: turner] #371253
07/09/09 06:49 PM
07/09/09 06:49 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
