Milodon gear drive oiling #370641
07/09/09 12:47 AM
07/09/09 12:47 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Milodon gear drive for street and strip use, Should I drill a galley plug to get more oil to the gears or will it be ok as is.
Re: Milodon gear drive oiling [Re: galen] #370642
07/09/09 07:34 AM
07/09/09 07:34 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
There should be enough splash from the pan.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Milodon gear drive oiling [Re: chryco] #370643
07/09/09 08:02 AM
07/09/09 08:02 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
whts the little hole in the left side middle of the milodon cover for?
Mopar Performance
Re: Milodon gear drive oiling [Re: moparniac] #370644
07/09/09 10:55 AM
07/09/09 10:55 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
If it's the one I'm thinking, it's for a timing pointer.
