Which trans cooler for street/ strip #370206
07/08/09 06:28 PM
07/08/09 06:28 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
The next item I need to purchase is a trans cooler for my Allstate.
I am going to mount it under the pass floor horizontally.
The coolers are rated at vehicle weight and some for HP.
My car is around 2500lbs and the HP should be 700 ish + or -. Torque converter is PTC 9.5".
Will the B&M Super cooler for 24,000 lbs rating be able to keep the trans cool in a street situation?
This is the one I am looking at.
http://www.summitracing.com/parts/BMM-70272/
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Which trans cooler for street/ strip [Re: Hemi Allstate] #370207
07/08/09 11:28 PM
07/08/09 11:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mark,if you are mounting that way,I would use a cooler with it's own cooling fan on a switch
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Which trans cooler for street/ strip [Re: hemi-itis] #370208
07/08/09 11:56 PM
07/08/09 11:56 PM
Mt. Eden Ky.
Mt. Eden Ky.
Well, that was my original plan Al, but most are 3.5- 4" thick and my frame is 2x3" tubing. I don't know if there is enough room for circulation? If the fan is on top it can't draw from there because of the floor. If it is on the bottom it can't blow through for the same reason. That is why I was thinking of going "fanless" .
Thanks for your input.
Mark
1996 Ram 1500 Sport
1968 road runner
