Trouble with cummins starting #370102
07/08/09 05:25 PM
07/08/09 05:25 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
When I go to start the truck in the morning( '98 5.9 12v cummins ) it wont start it just cranks. You have to try it about four different times before it will fire up. once it starts it shakes violently for a few seconds then it fine. When I start it after work it fires right up no problem. Any ideas appreciated
Re: Trouble with cummins starting [Re: 340Scamp] #370103
07/08/09 06:51 PM
07/08/09 06:51 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Air leaking into the return line at the rear of the head can cause this. They don't always leak fuel but will let ai into the line and prime is lost to the fuel injection pump.
Some of the mwtal lines has a seam leak that allowed this.
Re: Trouble with cummins starting [Re: fox] #370104
07/08/09 07:40 PM
07/08/09 07:40 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Thanks greatly appreciated. I'll take a look.
