Best intake for stage vi heads #369569
07/07/09 10:01 PM
07/07/09 10:01 PM
kansas
70B5Vert Offline OP
70B5Vert  Offline OP
kansas
Hey is the Mopar M1 for stage vi heads any good??
I like the idea of built-in valley tray into the intake.
seen so many aftermarket valley trays leak with alum heads.
suggestions??
current combo
3200lbs
440
915 heads mild cleanup
750 holley
torker II
590,s purple shaft cam
727 3500 stall
4.30 gears
cal tracs
hoosier 30x9
10.80,s
121mph
1.48 60ft
Picked up stage vi that flow
315 cfm
Suggest cam???
Intake???
CarB????
Thanks in advance
Deron
17 Charger Daytona
70 'Cuda 340 My 1st car
70 'Cuda 340 Vert
73 Duster 318
73 Cuda 440 Drag
1.405 60ft
10.243 et 130.54 mph
6172 Diecast Mopars
http://www.facebook.com/profile.php?id=100001409817007&sk=photos
Re: Best intake for stage vi heads [Re: 70B5Vert] #369570
07/07/09 10:12 PM
07/07/09 10:12 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I HAD stage VI heads ...had a torkerII intake with a Holley 1050..engine was a 448 RB..had a .557 cam..at 3300lbs the best the duster ran was 9.95 w/4.56 and 31" tires..
I brought the weight down under 2600lbs and changed the intake to the M1...made more power according to the chassis dyno and not pushing went 9.53..
I had read about different intakes at the time..the best being the edlebrock Victor and the M1 very close to within 5hp to each other..
Re: Best intake for stage vi heads [Re: smokinwoody] #369571
07/07/09 11:04 PM
07/07/09 11:04 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
On my motor 496,Stage VI, Edlebrock Victor, Hughes 272@.050 .619 solid lifter cam, Pro-systems 1000cfm 4150 carb,3400 with me in it, on street tires /mufflers [10.22@128.With a 1.41 60ft.
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Best intake for stage vi heads [Re: Wicked49670dart] #369572
07/08/09 09:39 AM
07/08/09 09:39 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Used a edlebrock Victor when i had my 452ci Stage six engine years back. Seemed to work every well.. The guy who has the engine now is still happy with it!
Re: Best intake for stage vi heads [Re: 70B5Vert] #369573
07/08/09 10:26 AM
07/08/09 10:26 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I used that intake on a 440 12.5:1 .590 purple cam stage VI 950 HP and it made 632 HP on engine dyno. I am not using that combo or intake now. PM me if interested in buying it. Don
Re: Best intake for stage vi heads [Re: 70B5Vert] #369574
07/08/09 10:38 AM
07/08/09 10:38 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
OOTB (Out Of The Box), the 4150 Stage VI RB intake does NOT work well. I won't go into details, but will tell you that it took a lot of work by an experienced intake porter to bring the one I had around. HOWEVER... even "fixed", it would still not be the right intake for what you've described, because it has Max Wedged-sized runner entries from the plenum and gives up a lot of torque below the peak as a trade-off for high rpm HP.
The biggest drawback I see to your combination is the limited stall (3500 flash?) converter you listed. If that's the converter you're sticking with, then use something like an MP M1 intake on RB spacers and a cam in the low-to-mid 250s at .050" on 108 LSA to keep the torque up. If you stepped up to something around 5000 stall, you could run something in the mid-260s.
I still like a Holley "950 HP" (not really 950 cfm, though), for a good performing carb on something like this. There are other options, but mine worked pretty well OOTB and didn't require too much tuning from there.
Re: Best intake for stage vi heads [Re: BradH] #369575
07/12/09 12:22 AM
07/12/09 12:22 AM
kansas
70B5Vert Offline OP
70B5Vert  Offline OP
kansas
The heads came with the intake spacers.
do you use these with the victor intake??
that was the first intake I was looking at
I was also looking at a 850 carb but appears a
950 may be better
the converter is an old Hemi "j" converter.
its a break apart that can be easily adjusted.
Thanks for all the gret info.
17 Charger Daytona
70 'Cuda 340 Vert
73 Duster 318
73 Cuda 440 Drag
1.405 60ft
6172 Diecast Mopars
Re: Best intake for stage vi heads [Re: 70B5Vert] #369576
07/12/09 01:11 AM
07/12/09 01:11 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
On a B block you can use a RB intake, no spacer.On your RB Block use a RB intake and you have to use the spacers....Matt
Re: Best intake for stage vi heads [Re: Wicked49670dart] #369577
07/12/09 04:13 AM
07/12/09 04:13 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
The spacers end up giving you a compound entry angle that is not conducive to good flow OOTB either! If you look at the angle that the floor of the head meets the floor of the spacer you will see what I mean.
Plus it will leave stains that appear to me is caused by liquid fuel dropping out of the fast flow when it hits that "ramp"
I used the Stage VI/ M1 intake which I know worked well on the dyno. It does have some porting done to it, clean up and match porting. Don
Re: Best intake for stage vi heads [Re: cudadon] #369578
07/12/09 06:12 AM
07/12/09 06:12 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Mine worked well on my 496 stage 6 street combo, it was a 4150 flange with minor work done in the plenum. Ran 99 mph in the 1/8th in a fully loaded 4000+lb 71 charger .
Re: Best intake for stage vi heads [Re: CokeBottleKid] #369579
07/12/09 12:13 PM
07/12/09 12:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mines a bracket car. Dwayne ported the heads and it picked up nicely. I run a RB block and used to run the 4150 RB M1 and spacers using an 850 carb. I changed over to the RB M1 Stage VI specific 4500 intake and a ebay 4500 Carb Shop dominator. Picked up .4 and nearly 5mph. I did have the intake runners match ported quite a ways up the runners. I do not run max wedge ports, but they have been slightly enlarged over out of the box.
