Re: Big block gear drive question
[Re: FASTBACK66]
#369469
07/07/09 09:03 PM
07/07/09 09:03 PM
Posts: 857 The Dalles, OR.
Dusted_Ya
The Dalles, OR.
WELL! funny you ask... If this is the CAT one there's a hole series of crap that I had to do to make it work that they failed to mention in the instructions. So since I don't want to have to figure out to download images you can email me for images unless someone can tell me how I can download directly from my computer to here. I had to fab a spacer out of 1/8th inch aluminum that went on before the crank gear in order to move the oil slinger far enough away from the driver side idler button and still retain proper tolerances with the timing cover. I installed the idler button long ends towards the inside then had to grind the drivers side button down as much as possible and still have enough steel to retain the "C" clip (about 1/16")which moved the idler gear as far back as possible THEN... you have to grind down the cam gear button for proper tolerances... THEN dry install the timing cover and check all tolerances one more time and (preferably with the spark plugs pulled) hand turn the motor to make absolute freaken sure everything is smooth. Then you can reinstall the cover proper and your good to go! P.S. I got the quiet version which sounds like a Mc Donald Douglas DC-10 turbine engine (way freaken cool!)
[Re: Dusted_Ya]
#369470
07/07/09 09:27 PM
07/07/09 09:27 PM
Posts: 798 Nebraska
FASTBACK66
mopar addict
mopar addict
Nebraska
How ironic...It is a CAT one. Great, just what I wanted. I have to re-invent the wheel to install it,huh? Crap. This sucks. please. My e-mail is Damopar1@windstream.netVinny
[Re: demon440]
#369475
07/07/09 11:44 PM
07/07/09 11:44 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Could have left the slinger out.
......on any of the gear drives I've done, including the BB Chrysler,....leaving the slinger off is prefered, as more oil will climb onto the gears, which you want,...or you'll be replacing that drive after a few thousand miles,....do replace the front seal with a new quality seal,......gear drives are cool, when set up properly!
[Re: Dusted_Ya]
#369480
07/07/09 11:53 PM
07/07/09 11:53 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I put a Pete Jackson in the kids 62 413 like 9 years ago.Was an easy install.He has zero problems and the whine isnt all that bad.Plus his sees a lot of street miles and strip miles.Rocky
Chrysler Firepower
[Re: Dusted_Ya]
#369481
07/07/09 11:56 PM
07/07/09 11:56 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The oil slinger does nothing more than cover the front oil seal to keep excess oil from spraying onto it. Whoever told you that was drinking the bong water
Silly me!,....I've only been building/machining engines for about 30 years,....what do I know, sorry
[Re: DAYCLONA]
#369482
07/07/09 11:56 PM
07/07/09 11:56 PM
Posts: 798 Nebraska
FASTBACK66
mopar addict
mopar addict
Nebraska
Vinny
I couldn't see it in your second pic?,....or perhaps you did it afterwards, but remember to fold over the pointed ends of the sheet sloted shim behind the 3 cam bolts, this locks the bolts from looseing
Yeah I haven't got that far yet,but thanks for the reminder. Now I am torn on this oil slinger dilemma that's unfolding. Seems easier to leave it off but I have always heard you need it to keep the front seal from leaking. What to do?
Vinny
[Re: FASTBACK66]
#369485
07/08/09 12:45 AM
07/08/09 12:45 AM
RapidRobert
keep the slinger & drill a 1/64"(.015") hole in one of the front oil gallery plugs for a constant stream of pressurized oil to keep your gear drive happy(smart move w timing chains also).
[Re: RapidRobert]
#369486
07/08/09 04:07 AM
07/08/09 04:07 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Seems that the oiling issue has raised more Q's than A's.. Drilling into the oil galley plugs may be an innovative idea... so..what is the durability like of a gear drive..? How does the Milodon gear drive compare?
-------------------------------- Darren Beale Keith Black Racing Engines®
