Maiden Voyage on the New World Block.
#367845
07/06/09 10:12 AM
07/06/09 10:12 AM
Posts: 2,877 SE Nunya
Bubba
SE Nunya
Went to Ubly Dragway on Saturday for some 1/8 MI Shakedown runs. Best run was 6.28 @ 111.11 ---- 1.49 60" No Traction on any of the 5 passes made. I pulled 10* of timing out for 1.4 Seconds on the TransBrake. I ran 36.5* of timing and Short Shifted at 6500. A/F was showing 11.5.. What I learned was: * I need to get my Irons Racing Suspension in. * I need to get my Irons Racing Suspension in. * It wants 2 More degrees Timing. * I need to shift at 7400. * I need to take some Jet out. * I need to get my Irons Racing Suspension in. All in all.. I'm tickled with it.
Re: Maiden Voyage on the New World Block.
[Re: Bubba]
#367846
07/06/09 11:27 AM
07/06/09 11:27 AM
Cool!
Post deleted by Defbob
#367847
07/06/09 11:44 AM
07/06/09 11:44 AM
[Re: Bubba]
#367851
07/06/09 04:51 PM
07/06/09 04:51 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
After going over the numbers with my slide rule..... a 6.28 looks to equate to a 9.75-9.83 in the 1/4 mile,,, The IRONS suspension set up looks nice.... good luck bubba,,, you doing Norwalk or the NATS this year ?? Doc',,,,,
[Re: 69CHARGERMD]
#367852
07/06/09 09:31 PM
07/06/09 09:31 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Glad to hear you got it back out there. Look forward to hear the results once you get to tuning it..
[Re: Bubba]
#367855
07/06/09 10:10 PM
07/06/09 10:10 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Thats great Bubba, how was the World Block? Any problems you didnt see? Did you end up using the oil galley plug/port by the driver timing chain cover in your oiling system? I plan to with this Hemi. If My machinist would finish hone the block, and balance the rotating assembly..I could get it together...He's only had it since January... Wished I would have just hauled it to MI like I did the last one, and let Chuck and the boys finish it up...Bet it would have tookin them more than a month or two tops.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: BEEQUIK]
#367857
07/06/09 11:50 PM
07/06/09 11:50 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Once again.....the evil black Mirada is much too fast for my "good guy" white one to even consider contending with...... but I bet you'd enjoy my 1.37-39 60ft times! Psssst....you might look into re-doing your suspension, in case nobody mentioned it!
#367859
07/07/09 08:57 AM
07/07/09 08:57 AM
Bubba
SE Nunya
Thanks Everyone. The Combo is 512. Callies Crank, GRP Rods, CP Pistons, 345cc CNC -1's, Jesel Rockers, Scotty Brown Roller Cam. Dale Cubic Dominator, Hutch Built T-400 Trans, ATI Convertor, Dana 4.10, 10.5 tires, Leaf Springs, Mufflers, MSD7530. ALL this at a light weight of 3700 LBS. (Vince)Impastato Racing Engines did all the Block Machining. Jeff at Modern Cylinder Head touched up the Heads alittle and Scott Brown did the Cam Degreeing with the PITA Milodon Gear Drive. My Daughter and I did the assemble. I ended up plugging the Oil provision in the front of the block so I could use the parts I already had. The AN fittings are way too expensive to be changing stuff for no reason. Hey Doc, I'm planning on Norwalk this year. What are you charging for a Panus Cleansing these days? I now I can go faster if I was lighter. You all have a good idea cooking with that Irons Suspension suggestion. I think I'll call up the IronsWorks shop today for a chat.
[Re: Bubba]
#367860
07/07/09 09:07 AM
07/07/09 09:07 AM
Posts: 16,932 NC
440Jim
NC
That would be around 9.85-9.90 in the 1/4 pushing that heavy car down the track. And with better hook/sixty foot, even quicker.
[Re: 440Jim]
#367861
07/07/09 09:50 AM
07/07/09 09:50 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Nice job Bubba Must feel good to have the insurance of a good block to hold everything together. Keep us posted on your progress.
2 kids and a dog
[Re: Bubba]
#367864
07/07/09 09:21 PM
07/07/09 09:21 PM
Posts: 728 mi usa
old yeller
mi usa
