650 cfm too small? #367309
07/05/09 05:34 PM
07/05/09 05:34 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I just picked up a holley 650 double pumper real cheap but it is only 650 cfm. Is this too small for a 340? It has a comp xe268 cam, ld340, ported 2.02 J heads and hooker headers. Car is going to be mostly driven on the street with a few trips to the strip.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 650 cfm too small? [Re: 73cuda340] #367310
07/05/09 05:46 PM
07/05/09 05:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Have good low end but the higher end will suffer.
Re: 650 cfm too small? [Re: 73cuda340] #367311
07/05/09 05:48 PM
07/05/09 05:48 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Good carb for that combo.
Re: 650 cfm too small? [Re: MoparforLife] #367312
07/05/09 05:48 PM
07/05/09 05:48 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I think you would be happier with a 750-800 c.f.m.
Re: 650 cfm too small? [Re: MoparforLife] #367313
07/05/09 05:54 PM
07/05/09 05:54 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
650 will be fine unless you plan to rev over 6k.
Re: 650 cfm too small? [Re: Mr. T] #367314
07/05/09 05:55 PM
07/05/09 05:55 PM
florida
P
PJM Offline
PJM  Offline
P
florida
650 is perfect in my opinion! Most people make the mistake of over carburating.
Re: 650 cfm too small? [Re: Mr. T] #367315
07/05/09 05:55 PM
07/05/09 05:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Double pump, on a 4speed--GO FOR IT.
Do the cfm math, I bet you'd really have to wind that little sucker up before the carb would be holding you back.
Re: 650 cfm too small? [Re: 73cuda340] #367316
07/05/09 06:19 PM
07/05/09 06:19 PM
I just picked up a holley 650 double pumper real cheap Car is going to be mostly driven on the street
Should do good & you might consider going thru it(at least pull the bowls) just to make sure everything is correct(& clean).
Re: 650 cfm too small? [Re: RapidRobert] #367317
07/05/09 10:37 PM
07/05/09 10:37 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
650 DP should work very well . Did you ever race that Subaru ?
Re: 650 cfm too small? [Re: 73cuda340] #367318
07/06/09 12:27 PM
07/06/09 12:27 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
It will run fine, have great response but will suffer on the top end compared to a 750-800cfm carb.
When I swapped from a 625cfm Carter to a 850 TQ on my old Duster with a built 340 I could really FEEL THE DIFFERENCE when I tromped hard on the gas pedal while cruising.
Bigger secondaries are nice to have!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 650 cfm too small? [Re: MY340] #367319
07/06/09 12:44 PM
07/06/09 12:44 PM
P
Paul_Fancsali Offline
P
Currently working on a 650vac sec carb on a 340.Good low speed response but little lacking on high end 650 dbl pumpers are just about perfect on a street 340 I have several and overall hard to beat over all. I like a 750 on a light car the 650 on heavier. I have just built another 800 dbl pumper and its great on high end and ok at low speed due to the 4.56 gears on my 340 Duster. I have not track tested it to see what the 60fts and 330 are like, your combo a 650 dbl pumper might be a little small but it will out perform most any other carb
Re: 650 cfm too small? [Re: 73cuda340] #367320
07/06/09 01:29 PM
07/06/09 01:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
should be ok... if you need more mph you can always bump up the rear jets.
Coming soon!!!!
Re: 650 cfm too small? [Re: Dartcuda] #367321
07/06/09 07:38 PM
07/06/09 07:38 PM
clarks summit pa
clarks summit pa
Didn't race it yet, i will update that post when i do.
Re: 650 cfm too small? [Re: 73cuda340] #367322
07/07/09 10:36 AM
07/07/09 10:36 AM
clarks summit pa
clarks summit pa
How much will this 650 hold me back up top. Will it be enough to worry about or only a little bit.
Re: 650 cfm too small? [Re: 73cuda340] #367323
07/07/09 10:50 AM
07/07/09 10:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
with the 3.23's you'll be fine If you go to 3.91's you might need a little more. Make sure you run a spacer under the thing. A 1/2" 4 hole would do ya good.
Coming soon!!!!
Re: 650 cfm too small? [Re: 73cuda340] #367324
07/07/09 11:04 AM
07/07/09 11:04 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The carb will work fine with your mild combo,it won't hold you back if it's properly set up. Someone suggested bigger jets to help the top end power,very poor advice. Set it up to stock specs and it will work very well.
Re: 650 cfm too small? [Re: goldmember] #367325
07/07/09 12:16 PM
07/07/09 12:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
actually bumping them up a little can improve MPH. I wouldn't do it for regular driving but if he wants to blast it real good it might help.
Coming soon!!!!
Re: 650 cfm too small? [Re: Mr.Yuck] #367326
07/07/09 12:24 PM
07/07/09 12:24 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Adding jet doesn't make the carb act BIGGER or faster if its correct as is.If it's correct adding jet will slow it down.
Re: 650 cfm too small? [Re: 73cuda340] #367327
07/07/09 12:30 PM
07/07/09 12:30 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
My 650 Holley DP seems to be perfect for my combo. XE274 cam, AirGap, stock X heads, 3.91 gears, 3,500# car runs high 12's with the 650.
Everyone said it would run quicker with a Holley 750, we put one on and the car slowed down 3 tenths, even with tuning. Swapped the 650 back on and the car jumped right back.
Re: 650 cfm too small? [Re: goldmember] #367328
07/07/09 12:30 PM
07/07/09 12:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well...you can have a street set-up and a track set-up. I have found that some of MY vehicles enjoyed more timing and bigger secondary jetting at the track. All were run w/o air cleaner assemblies w/ fresh air hoods while racing. I also uncapped the exhaust. Adding a few gallons of 110 didn't hurt either.
Coming soon!!!!
