Re: cummins auto trans
[Re: mopardamo]
#365910
07/04/09 02:07 PM
07/04/09 02:07 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Hello,
Almost, The gear set is different. Diesels run at a much lower rpm.
Damon
Absolutely 100% untrue. Gear sets are exactly the same.
Both are 2.45 1st, 1.45 2nd, 1.00 3rd, and .069 OD.
Depending on the year it will either be a hydraulic shift valve body, or an electronic shift vavle body.
If it's a 47RH (hydraulic), the governer set shift points will be different between the two.
If it's a 47RE (electronic), the computer will control the shift point.
Also, the two use a different converter for different stall speeds.
