Recommendations for S/G lube
#364822
07/02/09 09:22 PM
07/02/09 09:22 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
Looking for recommendations for sure grip lube and friction modifiers.
Thanks Butch
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
Re: Recommendations for S/G lube
[Re: wheelsup68dart]
#364824
07/02/09 09:32 PM
07/02/09 09:32 PM
Posts: 7,506 Az
Crizila
Az
Most sure grip mfg's ( Auburn for sure ) do not recommend using synthetics. I use 80-90 gear lube and about 1/2 the recommended amount of friction modifier.
Fastest 300
[Re: Crizila]
#364825
07/02/09 09:55 PM
07/02/09 09:55 PM
RapidRobert
85-140 dino lube & a bottle of whale oil from MP
[Re: Pacnorthcuda]
#364829
07/03/09 01:40 AM
07/03/09 01:40 AM
Posts: 6,185 Bridgeport, WV
Michael
Bridgeport, WV
THe Ford Friction modifier is hard to beat. ITs the same formula as that of the good ol 'days. Mix it with any GL-5 gear lube you like.
I agree and it's dino. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RapidRobert]
#364830
07/03/09 09:07 PM
07/03/09 09:07 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Pac is GL-5 dino or synthetic?
GL-5 can be either. The -5 refers for an extreme pressure specification that rears need (the amount of pressure, per square inch on the contact patch of the pinion/ring, under load, is tremendous)
MOST all gear lube IS GL-5, the difficulty is finding a good selection of GL-4 for our manual trannys (the selection is few). Not a problem for diffs~
