TA 10" converter BAD????? #364545
07/02/09 04:27 PM
07/02/09 04:27 PM
NW PA
V10nacuda Offline OP
NW PA
I have been told a way to check if a converter is bad it to use a set of pliers & spin the splines inside back & forth. One way should be free & the return should be friction.
This one is free both ways... Is the sprag bad inside????
V10
Re: TA 10" converter BAD????? [Re: V10nacuda] #364546
07/02/09 05:11 PM
07/02/09 05:11 PM
If you call TA it will be! PTC is about the best for a "check out" and fix if needed--TA will charge you same as a new unit --no middle ground with them. I can't answer your original question but good luck. TA 10 in units were always a little loose in high gear--too much slip compared to other stuff IMO--I have had TA J units that were without doubt the best I have ever used FWIW
Re: TA 10" converter BAD????? [Re: V10nacuda] #364547
07/02/09 06:12 PM
07/02/09 06:12 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
i sent my 10" t/a to ptc to have the stall tightened up and a new neck put on it, this was in july 2008 and i was charged $150.00 plus shipping.it works awesome less slippage driving around,but it will flash when u put the power to it.it was a week turn around time also.
