Re: R5P7 DART TO TEST FRIDAY
[Re: SCDaytona]
#364270
08/31/09 08:28 PM
08/31/09 08:28 PM
http://videos.streetfire.net/video/Dodge-at-Greenfield_684899.htmFound this website the other night when I was looking to see if anyone else had a R5 in a drag car. I bought a roller cam version from Arrington's and put it in my Dart with a powerglide, 7000 converter, and 538 rear gear. The car has gone a best of 9.70 @ 139 mph. I've been tinkering with suspension and gears. You guys are right.. these motors like to rev. Change this weekend will be a Pro Systems 1000HP, replacing a 950 Holley. The link at the beginning is to some video a guy took earlier in the year....he still thinks it's a 340.
#364271
08/31/09 09:56 PM
08/31/09 09:56 PM
Posts: 6,139 Melbourne , Australia
LA360
Scott's engine had a baby camshaft in it, around 248 @ 0.050" if I recall. The torque peak may not be as high as some of the other engines. The dyno sheet I saw on one of these engines had a torque peak at around 6800-7000 with a camshaft that was smaller than usual. AL.....
Alan Jones
[Re: scottb]
#364274
09/01/09 10:21 AM
09/01/09 10:21 AM
what gear ratio and rpm are you working in on a pass?my cam is 275@50 and 792 lift 109cl.pulls hard in good air if it will cross at 8900 or 9000.my out out of the box 950 was real hard to get right because the motor seamed always want to pull gas from the acc pump shooters.Have you noticed any thing like this?youre car is a rocket,just fishing to see what i am missing
#364275
09/01/09 11:02 AM
09/01/09 11:02 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
what gear ratio and rpm are you working in on a pass?my cam is [Email]275@50[/Email] and 792 lift 109cl.pulls hard in good air if it will cross at 8900 or 9000.my out out of the box 950 was real hard to get right because the motor seamed always want to pull gas from the acc pump shooters.Have you noticed any thing like this?youre car is a rocket,just fishing to see what i am missing
He has a 28 inch tire, he originally thought it would like a 5.13 gear, but didnt,.Went to a 4.56 gear, and car now stripes at close to 8 grand, shifts it about 7800 waas way out of power band with the 5.13's the convertor being redone should pick the car up a good bit, he will have it out to see mighty soon.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
