Page 4 of 4 1 2 3 4
Re: R5P7 DART TO TEST FRIDAY [Re: SCDaytona] #364270
08/31/09 08:28 PM
08/31/09 08:28 PM
http://videos.streetfire.net/video/Dodge-at-Greenfield_684899.htm
Found this website the other night when I was looking to see if anyone else had a R5 in a drag car. I bought a roller cam version from Arrington's and put it in my Dart with a powerglide, 7000 converter, and 538 rear gear. The car has gone a best of 9.70 @ 139 mph. I've been tinkering with suspension and gears. You guys are right.. these motors like to rev. Change this weekend will be a Pro Systems 1000HP, replacing a 950 Holley. The link at the beginning is to some video a guy took earlier in the year....he still thinks it's a 340.
Re: R5P7 DART TO TEST FRIDAY #364271
08/31/09 09:56 PM
08/31/09 09:56 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Scott's engine had a baby camshaft in it, around 248 @ 0.050" if I recall. The torque peak may not be as high as some of the other engines. The dyno sheet I saw on one of these engines had a torque peak at around 6800-7000 with a camshaft that was smaller than usual.
AL.....
Alan Jones
Re: R5P7 DART TO TEST FRIDAY [Re: LA360] #364272
09/01/09 08:05 AM
09/01/09 08:05 AM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Yes it does have a small cam 249 259 when taking to the engine shop that is what they run in the restictor plate motors not a hole lot of cam .My motor made 735 hp and 515tq with the plate it made 430 406 so you cane seen how much they differance there is I think the car has a 20 in it soon
Re: R5P7 DART TO TEST FRIDAY [Re: scottb] #364273
09/01/09 10:11 AM
09/01/09 10:11 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Don is not doing to good on the smoking part. My boss and I made a complete new front end he used to race a lot of late model stuff and they used to build there own front ends so that help out a ton
Scottie boy...you better update them on the smoking thing
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: scottb] #364274
09/01/09 10:21 AM
09/01/09 10:21 AM
what gear ratio and rpm are you working in on a pass?my cam is 275@50 and 792 lift 109cl.pulls hard in good air if it will cross at 8900 or 9000.my out out of the box 950 was real hard to get right because the motor seamed always want to pull gas from the acc pump shooters.Have you noticed any thing like this?youre car is a rocket,just fishing to see what i am missing
Re: R5P7 DART TO TEST FRIDAY #364275
09/01/09 11:02 AM
09/01/09 11:02 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
what gear ratio and rpm are you working in on a pass?my cam is [Email]275@50[/Email] and 792 lift 109cl.pulls hard in good air if it will cross at 8900 or 9000.my out out of the box 950 was real hard to get right because the motor seamed always want to pull gas from the acc pump shooters.Have you noticed any thing like this?youre car is a rocket,just fishing to see what i am missing
He has a 28 inch tire, he originally thought it would like a 5.13 gear, but didnt,.Went to a 4.56 gear, and car now stripes at close to 8 grand, shifts it about 7800 waas way out of power band with the 5.13's the convertor being redone should pick the car up a good bit, he will have it out to see mighty soon.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: R5P7 DART TO TEST FRIDAY [Re: B3422W5] #364276
09/01/09 12:47 PM
09/01/09 12:47 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
The car has a carb shop 950 on it right now going to start playing around with the jetting soon My motor is just like it came from Arringtons I reset the timing and thets been it it has 456 gears 28 inch tire .Don is doing very well on the smoking part he has quit for a wk now thats good just keep going
Page 4 of 4 1 2 3 4
