Re: What model Mopars used the NOX valve
[Re: chargermop]
#362921
06/30/09 09:48 PM
06/30/09 09:48 PM
Posts: 12,431 Warren, MI
71TA
Warren, MI
my 74 360 4spd duster NOX'S valve was on the air cleaner not the firewall.. fyi
Good point. Maybe it was on the firewall for /6's?
Good info 6T6.
[Re: Challenger 1]
#362924
07/05/09 04:45 PM
07/05/09 04:45 PM
Posts: 4,165 Florida
cataclysm80
My 71 E body has one on the firewall.
I think they showed up on E bodies before 73. My 70 'Cuda SPD June 1970 does NOT have the NOX valve on the firewall, but DOES have dimples in the sheetmetal for its location. I've never seen the valve itself on a 1970 E, but have seen them on later years.
Tav
[Re: cataclysm80]
#362931
07/07/09 11:50 AM
07/07/09 11:50 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
I found this air cleaner on a car at a show in Daytona Beach. I'm pretty sure the car was an E body, but I don't remember much else about it. Lots of stuff had been changed, so who knows where they got this air cleaner. I took the picture because I've been meaning to ask... What's this thing on the side of the air cleaner?
Tav
That is probably the fresh air valve. Some 4bbl 72?-74? cars have a bananna shaped cutout underneath them to bypass the single snorkle air inlet and let in air from underneath the air cleaner. Those air cleaners are originally orange not wrinkle.
[Re: autoxcuda]
#362932
07/07/09 11:59 AM
07/07/09 11:59 AM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
My dad's 73 has the valve that you are talking about. It also has another valve of some type right next to it on the passengers side. The picture above just shows a block off plate where the valve is on dad's car.
Please explain the valves purpose and if it needs attention before I start reassembling the car. Are they available new?
[Re: cataclysm80]
#362933
07/07/09 11:59 AM
07/07/09 11:59 AM
cataclysm80
Here is some more info I've gathered. It's reliability is slightly questionable, so you might want to double check its accuracy.
In 1970 all cars used the Cleaner Air System (CAS)(PCV valve, valve cover vent, etc. In 1970 California cars used the Evaporation Control System (ECS)(fuel vapor setup) in addition to the CAS system.
In 1971 the ECS & CAS systems were used in the other 49 states, while California cars went to the NOX system in addition to ECS & CAS. The NOX system includes special components for the transmission, a special camshaft with more valve overlap, and a 185 degree thermostat. There were 2 different setups available depending on manual or auto trans.
Manual trans = a switch on the trans sensed what gear the car was in. any gear below high gear made a solenoid cut off the vacuum from the carb to the distributor vacuum advance unless the temperature sensor indicated the underhood temp was less than 70 degrees.
Auto trans = similar to above, but used a speed sensing switch inline with the speedometer cable.
In 1972 the ECS & CAS systems were used in the other 49 states, while California cars went to the Orifice Spark Advance Control (OSAC) & Exhaust Gas Recirculation (EGR) system in addition to ECS & CAS. OSAC is a firewall mounted valve with hoses to the carb and distributor vacuum advance. EGR is a valve on the intake manifold with a temperature unit on the firewall. The EGR system had slight differences depending on what engine was in the car. (318 ported, 340 floor jetted)
In 1973 the ECS, CAS, OSAC, & EGR systems became standard on all cars. I'm not aware of any differences for California cars in 73.
In 1974 the ECS, CAS, OSAC, & EGR systems were still standard on all cars. California cars used a venturi vacuum amplified EGR setup.
Tav
[Re: cataclysm80]
#362935
07/08/09 01:05 AM
07/08/09 01:05 AM
Posts: 28,597 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Sorry I don't remember the specific year of this car, but I know it is a 72-74 E body.
Tav
My 73 dart has the same as pictured
