Re: 426 hemi 172 teeth flywheel size HELP!!!
[Re: ts70rt]
#362165
06/30/09 08:27 AM
06/30/09 08:27 AM
Posts: 4,285 Ohio
64dodge572
Ohio
can someone please tell me the correct total across width on a 426 hemi 172 tooth flywheel. Thanks Tim
13.75" or 14.75" if you measure across the ring gear.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: ts70rt]
#362167
07/01/09 09:48 AM
07/01/09 09:48 AM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
Thanks for the help, what is the difference from the 13.75 and 14.75?
13.75 across flywheel surface
14.75 across OD of ring gear
If it's a restoration you're stuck with that direct drive setup if it's correct. If it's a driver, ditch it and put a 143t flywheel and a 383/440 cast bell with a mini starter on it.
