Page 4 of 8 1 2 3 4 5 6 7 8
Re: 64 Plymouth Fury project [Re: ] #361172
01/06/10 11:16 PM
01/06/10 11:16 PM
central ohio
mopar rookie Offline OP
central ohio
Sorry bigdad....just haven't been motavated lately but I have got some things done. Maybe you just gave me the nudge I needed to get back at it! Here is a few pics of my progress.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361173
01/06/10 11:27 PM
01/06/10 11:27 PM
central ohio
central ohio
Sealed the floor with KBS rust seal.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361174
01/06/10 11:34 PM
01/06/10 11:34 PM
central ohio
central ohio
I decided to use Dynamat on the floor. It's actually Jegs brand but it was eighty bucks cheaper than Dynamat.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361175
01/06/10 11:40 PM
01/06/10 11:40 PM
central ohio
central ohio
I don't know if it makes much of a difference using this stuff but I had in my mind I wanted it. I guess I watched Overhaulin to many times.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361176
01/06/10 11:42 PM
01/06/10 11:42 PM
central ohio
central ohio
Headliner installed.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361177
01/06/10 11:48 PM
01/06/10 11:48 PM
central ohio
central ohio
Got all of the trim installed on the door panels.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361178
01/06/10 11:49 PM
01/06/10 11:49 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
LOOKS GRRRRRRRRR 8 !!!!
Keep at it !!
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 64 Plymouth Fury project [Re: bigdad] #361179
01/25/10 10:47 PM
01/25/10 10:47 PM
central ohio
central ohio
Got a little bit more done this week. Got new gaskets and polished the lenses on the back up and tail light assemblies.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361180
01/25/10 10:49 PM
01/25/10 10:49 PM
central ohio
central ohio
Tail lights.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361181
01/25/10 10:50 PM
01/25/10 10:50 PM
central ohio
central ohio
Installed.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361182
01/25/10 10:52 PM
01/25/10 10:52 PM
central ohio
central ohio
Also got the back glass installed and the window trim.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361183
01/25/10 11:41 PM
01/25/10 11:41 PM
An Island in the Pacific N.W.
moopa Offline
moopa  Offline
What a beautiful job you're doing!
Mark
2015 TorRed Challenger Hellcat,A8 2013 Plum Crazy Challenger SRT8,6 Spd 2013 Black Challenger R/T Classic,auto (2)72 Satellites, one on hold,one under resto on the rotisserie.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361184
01/26/10 10:36 AM
01/26/10 10:36 AM
ohio
70shaker6pk Offline
super gas
70shaker6pk  Offline
super gas
ohio
Looking real nice, great work!
Re: 64 Plymouth Fury project [Re: 70shaker6pk] #361185
01/26/10 10:54 AM
01/26/10 10:54 AM
central ohio
central ohio
Thanks for the kind words. I will say it's been fun and frustrating at the same time. Trying now to get the windows adjusted to where they roll up right. I had them rolling up perfect into the rubber seal until I put the door panels on that changed everything. Try again tonight
Re: 64 Plymouth Fury project [Re: mopar rookie] #361186
02/06/10 11:59 PM
02/06/10 11:59 PM
Canada
Lugnutz Offline
Lugnutz  Offline
Canada
Well, are we done yet
Re: 64 Plymouth Fury project [Re: Lugnutz] #361187
02/09/10 05:34 PM
02/09/10 05:34 PM
central ohio
central ohio
Lugnutz your killing me! I would like to be done but we have white death here right now. I run a grocery store ya know so it's been a nightmare for me at work. I can't even blame you this time cause it's been coming from the south. Keep your Noreaster's and Alberta clippers to yourself!
Re: 64 Plymouth Fury project [Re: mopar rookie] #361188
03/16/10 07:40 PM
03/16/10 07:40 PM
central ohio
central ohio
Got a little more work done. The trunk is basically buttoned up. Had to cut the hole for the spare tire holder and jack. The mat is the molded type but it needs some heat to flatten out from being rolled up in the box. Also got the weather strip glued on.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361189
03/16/10 07:45 PM
03/16/10 07:45 PM
central ohio
central ohio
Also got the quarter trim and trunk trim put on. Had to modify clips for that trunk trim cause the needed to be bowed in the middle to make it fit right.
Re: 64 Plymouth Fury project [Re: mopar rookie] #361190
03/16/10 07:56 PM
03/16/10 07:56 PM
central ohio
central ohio
Had to buy 3 cans of paint to detail this little trunk trim. Probably sit on the shelf and go bad before I ever need it again
Re: 64 Plymouth Fury project [Re: mopar rookie] #361191
03/16/10 08:00 PM
03/16/10 08:00 PM
central ohio
central ohio
Rear window and roof rail chrome trim installed as well as dome light covers.
