Need .010 under T-chain
#360849
06/28/09 07:23 PM
06/28/09 07:23 PM
Posts: 289 Lowes
steve660
Lowes
Anyone know where to get .010 under T-chain for a 440? Preferably with a 9 way crank gear.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: Need .010 under T-chain
[Re: abodyman]
#360852
06/28/09 08:50 PM
06/28/09 08:50 PM
Posts: 289 Lowes
steve660
Lowes
Any idea where to get a Rollmaster chain??
[Re: GLR]
#360857
10/31/09 01:02 PM
10/31/09 01:02 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I know that this sounds dumb, but is there an easy way to tell which (.005 or .010) reduced distance is needed? The new stock length chain is way loose and I know that the engine was line bored but no longer have the paperwork.
This is the land of the free
because of the brave
[Re: JoesMopar]
#360861
10/31/09 04:28 PM
10/31/09 04:28 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
Not an expert on this but if you line BORE (not hone) the mains on your block because you have missmatched main caps or new main caps, the boring changes where the center line of the crank rides in relation to your deck height. Therefore the distance between the center line of you crank is closer to the center line of you cam, therefore a standard length timing chain will be loose. That's muy understanding Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: Snoopy]
#360863
11/01/09 06:22 AM
11/01/09 06:22 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Is the chain shorter or are the gears larger in diameter?
Gears larger, chain stock is standardized AFAIK.
[Re: rbstroker]
#360867
11/01/09 10:10 PM
11/01/09 10:10 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
Cloyes has the center distance spec. listed in their catalogue. Measure across the crank and cam noses (or between them) and do the math.
Randy
