LD4B for 318 #360098
06/27/09 11:01 PM
06/27/09 11:01 PM
Windsor, Ontario
P
project74 Offline OP
P
Windsor, Ontario
About ready to put a 4 brl on a stock '70 318 and have hit an issue. From what I can gather, the intake port dimensions on a 318 2 brl head are about .97 x 1.95. I've got a really nice ld4b but it looks to have been gasket matched at some point. Port height is no problem but the width is a whopping 1.08 on a couple of the ports. Is this going to cause a big issue, the old slamming the bigger hose into the smaller? Or is a .13 difference not something I should worry about? Carb will be a '70 AVS if that makes any difference. Any and all advice appreciated. Thanks
1970 Fury III, 318, 4 dr hardtop, aka "The Fridge"
Re: LD4B for 318 [Re: project74] #360099
06/27/09 11:08 PM
06/27/09 11:08 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use a good composite gasket and be happy. May have trouble sealing the tin type gasket. Good manifold.
Re: LD4B for 318 [Re: project74] #360100
06/27/09 11:11 PM
06/27/09 11:11 PM
Not ideal but for a stock setup such as yours if you can get the right gasket for it to seal you'll be OK
Re: LD4B for 318 [Re: project74] #360101
06/28/09 12:20 AM
06/28/09 12:20 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I just put that manifold on my stock 70, 318, I used a composite gasket and a good RTV sealer. My ports where smaller that the manifold as well. Sorry, I didn’t measure mine though. It works great and has tons of power now. On a stock motor, it should be no problem.
My Monster are real!
Living within your means makes life pretty easy.
Re: LD4B for 318 [Re: 67vertman] #360102
06/28/09 10:18 AM
06/28/09 10:18 AM
scratchnfotraction Offline
not a big deal on the stock heads of a 318
I have run many 360 intakes on the 318 heads
you will notice nothing in performance other than a boost from a 4=v on it
I run a LD4B on my 360 headed 318 and works fine,lots of torque and throttle responce
mpgs ar not that bad either
I use a felpro gasket #1213 IIRC
Re: LD4B for 318 [Re: scratchnfotraction] #360103
06/28/09 01:30 PM
06/28/09 01:30 PM
Windsor, Ontario
P
P
Windsor, Ontario
Thanks guys. Nice to know I don't have to hunt down another intake I can afford.
