is it normal? #357434
06/25/09 09:33 AM
06/25/09 09:33 AM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
is it normal for passenger tire on my 73 duster to be stickimg out about 1/2" farther out towards my fender then tire on drivers side, i dont mean slanting out or anything like that, just straight up and down, rim is all the way against the drum and everything is tight, no vibrations, thanks sorry i wasnt so clear it is on the front
Re: is it normal? [Re: don b] #357435
06/25/09 09:42 AM
06/25/09 09:42 AM
Az
Crizila Offline
Crizila  Offline
Az
No, but 1/2" really isn't alot. Check the wheel offset first. Then start measuring other suspension components. Don't count out sheet metal alignment.
Fastest 300
Re: is it normal? [Re: Crizila] #357436
06/25/09 11:21 AM
06/25/09 11:21 AM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
thanks, it doesnt seem to be hurting anything, i guess if it aint broke dont fix it, just saught my eye after i out bigger tires on front
Re: is it normal? [Re: don b] #357437
06/25/09 12:23 PM
06/25/09 12:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
my charger does have passenger front wheel around 1" deeper down the fender more than driver side. And is not the only one
Re: is it normal? [Re: NachoRT74] #357438
06/25/09 03:18 PM
06/25/09 03:18 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
IF we are talking about the rear wheels then yes it's normal. The factory was never very careful on getting the spring perches centered on the rear end. Every old Mopar I have the wheels are closer to the fender lip on one side than the other at least somewhat.
I see now you said front tire...usually they are pretty even but 1/2" off isn't surprising.
Re: is it normal? [Re: 440newport] #357439
06/25/09 04:03 PM
06/25/09 04:03 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
thanks all
