Re: Moparts fast car list, post yours!
[Re: G_bob]
#35690
05/28/07 10:59 AM
05/28/07 10:59 AM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
5.59 ET @ 256 MPH 451 CRE/BAE Hemi 2003 Bowen RED Challenger125 6.360 @ 208 .941 60' 4.02 1/8 173 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.65 @ 179.98, 1.12 60' 1970 Cuda 550ci Larry Morgan Hemi torqueflite naturally aspirated 3000# 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.22 @163, 1.161 60', 540 Indy, 86 Daytona, 2450#,All Motor Alky Injected. 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.95 @154.5 69 AMX 434 amc. street tires and muffs.lots of Bottle.3345 lbs 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.16 @ 147.5 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.41 @ 142.98, Lil' Demon, '71 Demon, 3200lbs, all motor 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582 @ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 140.12 Cudafied.. RB-499, Indy SR, t-flite, t-brake, 8 3/4 w/4.56's, Ladder bar, 3240# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.62 @ 140.8 Hurst390 80 AMX 420 AMC Iron Heads 2950# 4-speed Street Car!? 9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials, Cal-Tracs 9.66 @ 138.27, MoparChas 1970 Challenger 495 CID 3160 lbs w/DRIVER all motor 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @ 136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor 9.983 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088 @ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.54 @ 127, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.03 @ 121.71, G-bob, 1.58 60', 3650 lb 67 Coronet [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.82 @ 115.36, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950# w/ me 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim 12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.93 @ 105, greenduster, 340/727, SS Springs, 4.30 gear 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 12.981 @105.88, 1.969 60', David_in_St_Croix, 70 post RR, 383, eddy heads, 10.2:1, 4 speed, 3.73 SG, daily driver 13.752 @ 102, 1.97 60', '71 383 Challenger w/MP 280 cam, headers and 3.91 gears on ET streets 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
[Re: Diego_Ted]
#35691
05/29/07 07:38 AM
05/29/07 07:38 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
5.59 ET @ 256 MPH 451 CRE/BAE Hemi 2003 Bowen RED Challenger125 6.360 @ 208 .941 60' 4.02 1/8 173 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va) ---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.65 @ 179.98, 1.12 60' 1970 Cuda 550ci Larry Morgan Hemi torqueflite naturally aspirated 3000# 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383 ---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.22 @163, 1.161 60', 540 Indy, 86 Daytona, 2450#,All Motor Alky Injected. 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.95 @154.5 69 AMX 434 amc. street tires and muffs.lots of Bottle.3345 lbs 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot ---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.16 @ 147.5 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.41 @ 142.98, Lil' Demon, '71 Demon, 3200lbs, all motor 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582 @ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 140.12 Cudafied.. RB-499, Indy SR, t-flite, t-brake, 8 3/4 w/4.56's, Ladder bar, 3240# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.62 @ 140.8 Hurst390 80 AMX 420 AMC Iron Heads 2950# 4-speed Street Car!? 9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials, Cal-Tracs 9.66 @ 138.27, MoparChas 1970 Challenger 495 CID 3160 lbs w/DRIVER all motor 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @ 136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor 9.983 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it. ---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088 @ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.54 @ 127, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020# ---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.03 @ 121.71, G-bob, 1.58 60', 3650 lb 67 Coronet [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.82 @ 115.36, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950# w/ me 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed. ---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim 12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.93 @ 105, greenduster, 340/727, SS Springs, 4.30 gear 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 12.981 @105.88, 1.969 60', David_in_St_Croix, 70 post RR, 383, eddy heads, 10.2:1, 4 speed, 3.73 SG, daily driver --13 second zone --- Moparmal - 13.66 at 99.88 mph, 2.1 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.7 gears on road 27" radial tyres. ![](/ubbthreads/images/graemlins/shock.gif) 13.752 @ 102, 1.97 60', '71 383 Challenger w/MP 280 cam, headers and 3.91 gears on ET streets ---14 sec zone-- 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
[Re: Moparmal]
#35692
05/30/07 07:00 PM
05/30/07 07:00 PM
Posts: 4,103 Yes
sixpakdodge
Yes
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088 @ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.54 @ 127, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---14 sec zone--
14.025@ 96.08 sixpakdodge, 72 Dart Swinger 318 Auto
[Re: sixpakdodge]
#35693
05/31/07 04:04 PM
05/31/07 04:04 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.03 @ 121.71, G-bob, 1.58 60', 3650 lb 67 Coronet [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 115.2 69 Dart, 340,727, 1.57 60', pump gas street/strip 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.82 @ 115.36, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950# w/ me 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---14 sec zone--
[Re: justinp61]
#35694
06/05/07 02:24 AM
06/05/07 02:24 AM
Posts: 2,937 A shed in England
Tig
A shed in England
---5 second Zone--- 5.59 ET @ 256 MPH 451 CRE/BAE Hemi 2003 Bowen RED Challenger125 ---6 second Zone--- 6.360 @ 208 .941 60' 4.02 1/8 173 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va) ---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.65 @ 179.98, 1.12 60' 1970 Cuda 550ci Larry Morgan Hemi torqueflite naturally aspirated 3000# 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383 ---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.22 @163, 1.161 60', 540 Indy, 86 Daytona, 2450#,All Motor Alky Injected. 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.95 @154.5 69 AMX 434 amc. street tires and muffs.lots of Bottle.3345 lbs 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot ---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.16 @ 147.5 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.41 @ 142.98, Lil' Demon, '71 Demon, 3200lbs, all motor 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582 @ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 140.12 Cudafied.. RB-499, Indy SR, t-flite, t-brake, 8 3/4 w/4.56's, Ladder bar, 3240# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.62 @ 140.8 Hurst390 80 AMX 420 AMC Iron Heads 2950# 4-speed Street Car!? 9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials, Cal-Tracs 9.66 @ 138.27, MoparChas 1970 Challenger 495 CID 3160 lbs w/DRIVER all motor 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @ 136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.94 @ 135.8, 1.47 60ft. Tig. 572ci '74 Challenger 3821 lb. street legal N/A. 9.952 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor 9.983 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it. ---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.54 @ 127, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020# ---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.03 @ 121.71, G-bob, 1.58 60', 3650 lb 67 Coronet [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 115.2 69 Dart, 340,727, 1.57 60', pump gas street/strip 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.82 @ 115.36, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950# w/ me 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed. ---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim 12.89 @ 101, '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.93 @ 105, greenduster, 340/727, SS Springs, 4.30 gear 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 12.981 @105.88, 1.969 60', David_in_St_Croix, 70 post RR, 383, eddy heads, 10.2:1, 4 speed, 3.73 SG, daily driver --13 second zone --- Moparmal - 13.66 at 99.88 mph, 2.1 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.7 gears on road 27" radial tyres. 13.752 @ 102, 1.97 60', '71 383 Challenger w/MP 280 cam, headers and 3.91 gears on ET streets ---14 sec zone-- 14.025@ 96.08 sixpakdodge, 72 Dart Swinger 318 Auto
[Re: Tig]
#35695
06/10/07 05:53 PM
06/10/07 05:53 PM
Posts: 4,103 Yes
sixpakdodge
Yes
13.752 @ 102, 1.97 60', '71 383 Challenger w/MP 280 cam, headers and 3.91 gears on ET streets 13.900 @ 97, sixpakdodge, '72 Dart Swinger, 318/727
---14 sec zone--
[Re: sixpakdodge]
#35696
06/13/07 12:41 PM
06/13/07 12:41 PM
Posts: 1,449 Commerce, Michigan
EasyG
Commerce, Michigan
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.39 @ 127.07, 1.41 60' 1badswinger, 3185#, 446 cid, edelbrock heads, all motor. 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.54 @ 127, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---14 sec zone--
Re: Moparts fast car list, post yours!
[Re: EasyG]
#35697
06/16/07 08:49 AM
06/16/07 08:49 AM
10.37 @129.76 SUPERSTOCKRACER 1.42 60'FT. 727 Torqueflite with low gear set 4.10 Dana 60,footbraking only & pushbutton shifter.
#35698
06/17/07 12:29 AM
06/17/07 12:29 AM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
13.01 @107.93; 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T;2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk. Moparmal - 13.66 at 99.88 mph, 2.1 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.7 gears on road 27" radial tyres.
---14 sec zone--
13.01 @107.93; 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T; 2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk.
Post deleted by Defbob
[Re: 70sixpkrt]
#35699
06/17/07 10:10 AM
06/17/07 10:10 AM
#35700
06/24/07 10:33 AM
06/24/07 10:33 AM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.16 @ 147.5 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.41 @ 142.98, Lil' Demon, '71 Demon, 3200lbs, all motor 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.436 @ 142.51 Eric 80 Arrow on motor 446 SR #2360 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 140.12 Cudafied.. RB-499, Indy SR, t-flite, t-brake, 8 3/4 w/4.56's, Ladder bar, 3240# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.62 @ 140.8 Hurst390 80 AMX 420 AMC Iron Heads 2950# 4-speed Street Car!? 9.64 @ 139.03, a9sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials, Cal-Tracs 9.66 @ 138.27, MoparChas 1970 Challenger 495 CID 3160 lbs w/DRIVER all motor 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @ 136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.94 @ 135.8, 1.47 60ft. Tig. 572ci '74 Challenger 3821 lb. street legal N/A. 9.952 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978 @ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor 9.983 @ 133.89, ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.39 @ 127.07, 1.41 60' 1badswinger, 3185#, 446 cid, edelbrock heads, all motor. 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.41 @ 128, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---14 sec zone--
[Re: Diego_Ted]
#35701
06/24/07 07:03 PM
06/24/07 07:03 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.39 @ 127.07, 1.41 60' 1badswinger, 3185#, 446 cid, edelbrock heads, all motor. 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.41 @ 128, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.88 @ 123.55, G-bob, 1.53 60', 3650 lb 67 Coronet 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 115.2 69 Dart, 340,727, 1.57 60', pump gas street/strip 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.82 @ 115.36, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950# w/ me 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---14 sec zone--
[Re: G_bob]
#35702
06/24/07 07:50 PM
06/24/07 07:50 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver [Email]11.07@119.64[/Email] 1.53 60' 446 66 CORONET 3640lb Vernmotor 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.39 @ 116.65 1.54 60' 75 Duster on throttle/no bottle/587 heads Knowsnothing 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 115.2 69 Dart, 340,727, 1.57 60', pump gas street/strip 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @ 113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.81 @ 115.42, 1.698 60', 67Charger, '67 Charger, 440/727 (rev. man.), 4.10's, 3950#, full exhaust 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---14 sec zone--
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#35703
06/24/07 09:48 PM
06/24/07 09:48 PM
Posts: 2,273 Greenville, South Carolina
BBLM23
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers 10.018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.046 @ 134.12, BBLM23, 1981 Dodge Aries, mufflers, little 750 cfm on 451 with B1/BS heads 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @ 131.42, 440PURSUIT, 1.375 60' 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @ 129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.39 @ 127.07, 1.41 60' 1badswinger, 3185#, 446 cid, edelbrock heads, all motor. 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.41 @ 128, 1.43 73 Duster 3500# SB 416, Batton Heads All Motor, "El Picoso" Diego-Ted 10.43 @ 127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 124, imin269, 69 Cuda FB, 3200lbs. 395"SB pump gas. Naturally Asp. 1.44 60 foot 275 60-15 Drag radial. Full exhaust to factory tips. QUIET! 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.88 @ 123.55, G-bob, 1.53 60', 3650 lb 67 Coronet 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---14 sec zone--
Walter 1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph Racing Pro in street trim. 1981 Aries ARC 548 B1 8.88 at 147mph (footbraking) 1996 Ram 2500 V10 16.52 at 80mph 1981 Reliant 400
[Re: BBLM23]
#35704
06/25/07 01:36 PM
06/25/07 01:36 PM
Posts: 356 Rochester, NY
superb70
Rochester, NY
13.008 @ 105.4 ; Superb70, 70 Super Bee, 9.6:1 440 W/516's & .474,280 purple shaft ,manual 727 , 4.10 sure grip
---14 sec zone--
[Re: superb70]
#35705
06/28/07 12:04 AM
06/28/07 12:04 AM
Posts: 1,730 Red Deer, Alberta
bill_greenwood
Red Deer, Alberta
1969 Dart, 366 ci, ported j-heads, MP 528 solid, 904, 4.88, 904, 3200 lbs. 11.53@117 w/1.68 60 ft. 3300' DA. Bill Greenwood.
[Re: Dartman928]
#35706
06/30/07 05:00 PM
06/30/07 05:00 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I have started a new post to allow the 22 extra pages to go away! All the info on page 22 is copied and pasted here. Please up date any missing times before old post gets too far gone. To up date with a new ET, just click quote on this post, then add your et and info in the proper order of the post, remove quote brackets, hit submit.
6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 136 Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor [Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10:347@127:69 Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas.. 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.19 @ 122, G-bob, 1.64 60', 3650 lb 67 Coronet 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim [Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
[Re: Cab_Burge]
#35707
07/01/07 07:02 PM
07/01/07 07:02 PM
Posts: 6,355 Cambridge Vt.
mark_gates
Cambridge Vt.
6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va) ---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383 ---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot ---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 136 Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor [Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it. ---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.15 @135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10:347@127:69 Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020# ---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas.. 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.19 @ 122, G-bob, 1.64 60', 3650 lb 67 Coronet 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed. ---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim [Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
[Re: mark_gates]
#35708
07/06/07 08:34 AM
07/06/07 08:34 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Someone left the whole 13 sec zone out of the post, so ive included it again..... ![](/ubbthreads/images/graemlins/eeek.gif) 6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va) ---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.78 @ 177.63, 1.10 60', PlumCrazyCharger, '68 Charger, 561 B1MC, 1.80 PG, 2680# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383 ---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot ---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.22 @ 147.7 DusterDave '73 Duster, Blown 528 HEMI, DOT's 3380# 9.22 @ 143.53 511 cu in 1.31 60 ft '68 Barracuda 2905 lbs Stage VI Mopar heads All Motor Single 4 bbl 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver.Fiberglass Springs Ladder bar,32x14x15 Aluma-stars under the chassis(Stock Rear Frame)Leaving at 2800RPM Shift At 7200RPM,5.38 Dana 727 GrinerBrake County Line Racing Trans,501 Indy Headed RB Single 9375-1050 Dominator carb.ALL THROTTLE NO BOTTLE. 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.42 @ 143.10 SSDA3426 1967 Coronet R/T 1.245 60' with the Rear Wheels.4170#'s with driver 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.47 @ 142.56 SSDA3426 1967 Super Stock Dodge HEMI Coronet.1.26 60' With Rear Wheels,32x14x15 GOOD/YEAR Slicks(under chassis stock Frame and floors/chassis).4170#s with driver.439.6 CI SUPER STOCK LEGAL 426 HEMI.Launch at 2400RPM shift 8200RPM.County Line Racing 727 Trans with Griner Gen III Billet Brake.THIS IS A TRUE HEMI SUPER STOCKER!! 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 136 Dartman928, 74 Dart Sport all motor,pump gas, mufflers, street car, 28" by 10" tire 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor [Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it. ---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.15 @135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 132.16 1.477 60' 74 Duster PRH446 Street tires through the Muffs 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10:347@127:69 Cabs Duster 3400# on pump gas cork up, air cleaner on ET Street Radails 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020# ---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.09 @ 118.95, 1.47 60', D.SLOAN, 395" SB in a 3250 lb. 69 Cuda, pump gas.. 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.19 @ 122, G-bob, 1.64 60', 3650 lb 67 Coronet 11.21 @ 118.75, 1.55 60', DusterW2, 340 W2, 904, 3165#, 10" tire, SS Springs. 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed. ---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.24 @ 115 1.59 60' SSDA3426 1968 Barracuda Full Street Trim,340 with .030 10.1 pistons Stock X-Heads, 727 Cheetah Man Rev V.Body,Hoosier Quick-Time 275x60Dx15 Street tires,8 3/4 with 4.88 spool.This car is Street LEGAL & Driven.It has been a Deadly Competitive machine. 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim [Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock --13 second zone --- 13.008 @ 105.4 ; Superb70, 70 Super Bee, 9.6:1 440 W/516's & .474,280 purple shaft ,manual 727 , 4.10 sure grip 13.01 @107.93; 70sixpkrt, 70 Charger 440-6pk 4-speed with .007 R/T;2.08 60', BFG T/As spinning off the line. Spare tire and coolers in the trunk. 13.66 at 99.88 mph, - Moparmal - 2.1 60',72 stroked 318(349), Comp 282s cam, Oz Charger 3.7 gears on road 27" radial tyres. 13.752 @ 102, 1.97 60', '71 383 Challenger w/MP 280 cam, headers and 3.91 gears on ET streets 13.900 @ 97, sixpakdodge, '72 Dart Swinger, 318/727 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
Re: Moparts fast car list, post yours!
[Re: Moparmal]
#35709
07/10/07 11:30 AM
07/10/07 11:30 AM
Posts: 481 Cheswick, PA
Bob_Spelic
Cheswick, PA
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.0714 @ 131.27, 1.366 60' ftbrkn Dustinu 396W5 @3300# 71 duster 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.086, 134.2, 1.46 60', 66 Dodge Charger, 3700#, 493, ported EZ-1, 14.5:1 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.15 @135.65, 1.41 60', 6.46 1/8 mark gates 75 AMC Pacer Indy EZ's by PRH 511 lowdeck, 3650lbs footbrake/NA
