dyno numbers vp 109 vs E-85
#355997
06/23/09 07:48 PM
06/23/09 07:48 PM
Posts: 140 sweden
street_dart
sweden
The engine:
400 block hardblock and alu mains 4.15 crank 4.375 bore flat topp ross pistons att the deck
ported B1-BS flow 350@ .700 milled to 67cc chamber 1009 feel pro 13.7-1 comp ratio Scott Brown roller cam .728/.720 274/285@050 112LSA instaled @ 109 int cent Isky endurance lifter
Indy 400-3 4500 intake ported to head.
2"-3.5" open headers.
Vr-1 10-60 oil.
Garry Williams E-85 1050 carb.E-85 from pump.
Holley 9375 fuel carb. VP-109
What do you think it made on a Go Power engine dyno?
Dodge Dart-67
Dodge Custom Royal Lancer-55
Dodge Dakota 4.7 -05
Re: dyno numbers vp 109 vs E-85
[Re: momopar]
#355999
06/23/09 08:09 PM
06/23/09 08:09 PM
Posts: 140 sweden
street_dart
sweden
The AFR was att 12.2-1 with the e-85 and the VP fuel.
It made some nice nr's.
Dodge Dart-67
[Re: street_dart]
#356005
06/23/09 11:07 PM
06/23/09 11:07 PM
Posts: 403 Laredo, Texas USA
hugo
Laredo, Texas USA
Sound like some excellent number. I have a similar combo with less lift and duration. My cam is 269int and 273ex lit is at 696. my engine only made 761hp at 6200 wiht indy heads flowing 358 at 700. Tq 695. My car ran great its a 69RR weight is 2888 readky to race and it went 9.28 at 3700 corrected altitude. Keep us posted how your car runs so we can see how your dyno # match to track resutls.
[Re: hugo]
#356006
06/23/09 11:51 PM
06/23/09 11:51 PM
Posts: 140 sweden
street_dart
sweden
I will post you some ET numbers when i get some. The heads earlier made 820Hp on one other engine and dyno. That motor had an smaler cam and less comp. The thing that konfused me was the bigg diff in power betwen e-85 and VP fuel. 60Hp and over 30 Ft/lbs is a lott djust swithing carb!
Dodge Dart-67
[Re: street_dart]
#356007
06/24/09 12:21 AM
06/24/09 12:21 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
if that e85 carb is a 4150 carb, throw that test out the window
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: mr_340]
#356009
06/24/09 06:12 AM
06/24/09 06:12 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Get your A/F ratio corrected for E-85 and you'll see it kick azz. Stoich is 9.765-1, maxpower rich is 6.975-1. So I's say you're wayyyyyyy lean. That's another nice feature of E-85, it's alot more forgiving than straight gasoline. Try going that much lean on gas once and you'll have an expensive paperweight.Dave
[Re: street_dart]
#356010
06/24/09 06:58 AM
06/24/09 06:58 AM
Posts: 1,664 North Sweden
RT540
North Sweden
Hi Kasper ! Actualy the B1BS heads only made 811hp on my 540. Nice to see they worked out so good for you I guess you didnīt run this last weekend. As I read( on klotterplanket), most of saturday rain out, and some rain on sunday to.
Tom
[Re: quickd100]
#356011
06/24/09 07:04 AM
06/24/09 07:04 AM
Posts: 140 sweden
street_dart
sweden
The e-85 carb is a brand new 4500 from Garry Williams. The dyno has a wide band lamda. We tested up and down with bouth timing and afr. I was disappointed when it gave more of gasoline and the guy who owns dynon laughed because he had said that vp-109 petrol was better before we tested. So i dont know what went wrong
Dodge Dart-67
[Re: RT540]
#356012
06/24/09 07:17 AM
06/24/09 07:17 AM
Posts: 140 sweden
street_dart
sweden
Hi Kasper ! Actualy the B1BS heads only made 811hp on my 540. Nice to see they worked out so good for you I guess you didnīt run this last weekend. As I read( on klotterplanket), most of saturday rain out, and some rain on sunday to. Tom
Hi Tom!
No, I drove nothing. the car was completed late Friday night and the weather was too bad for the trail all the way to Orsa. Excuse for the wrong data about your power. Blame my bad memory.
Dodge Dart-67
[Re: street_dart]
#356013
06/24/09 07:22 AM
06/24/09 07:22 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
something is wrong somewhere. I've yet to switch one without picking up. We use a gas A/F meter and tune very close to gas ratios. It is more forgiving than gas, but I just go to max power and that's where the A/F stays. we have a 615 single 4 on the dyno right now that has 60+HP spread from one carb to the other on the same fuel, so that's no surprise. Patrick from prosystems carbs. The one that makes more is only .070 larger bore, it's 40 more average and over 60 more peak. I know Gw can make a gas carb work, but maybe somethings off with E85. there's more 02, volume,and cooling with E85, so don't give up yet. Get the right carb on it and it will pick up.
[Re: dthemi]
#356014
06/24/09 08:49 AM
06/24/09 08:49 AM
sixpackgut
Charleston
i think i would have tried jetting the box stock holley up for E85.
[Re: dthemi]
#356015
06/24/09 09:30 AM
06/24/09 09:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I didnt dyno test my change but on track the switch to E-85 the car ran IDENTICAL but I didnt make a single change other than the carb and fuel, I still havent tweeked in jetting or timing.... so it wasnt less power thats for sure.... JMO
[Re: street_dart]
#356016
06/24/09 12:23 PM
06/24/09 12:23 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Did you test the E85 for actual content? I tested a couple stations this week and am still finding E70-E73. People are buying less because gas prices aren't that much different from E85. Don
