68 Dart GTS Tail stripe #35550
03/13/07 05:27 PM
03/13/07 05:27 PM
Albany, NY.
BBLOCKGT Offline OP
BBLOCKGT  Offline OP
Albany, NY.
Does anyone know the measurements of the bumblebee stripe for a 68 dart GTS? I want a custom color, I have a sign co. that will cut and install the strip if I can give them the size.
Thanks for your time.
Joe
Re: 68 Dart GTS Tail stripe [Re: BBLOCKGT] #35551
03/13/07 06:09 PM
03/13/07 06:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
We should get this added to the Best of Moparts, it gets old giving out the info.... Anyway, the dimensions are as follows:
From the edge of the first trunk body line (NOT the edge the finish panel would fasten too) the stripe starts at 4-3/4". Also, the stripe follows the crown of the trunk, it is NOT straight across! The first stripe is 1/4", then 1/2" gap, then 2-1/2" second stripe, then 1/2" gap, then another 2-1/2" stripe, then 1/4" gap, then the last 1/4" stripe. Also, if you look at the edge of the quarter panel at the low end where the edge of the bumper sits the stripe is 1/2" away from the start of the radius. Also, you can measure the first stripe from the edge of the quarter panel where the tail light bucket goes to 8-3/4". Just buy the vinyl stripe!
JB Rhinehart, Realist
A-Body's RULE!
