Re: Never buy a Mr Gasket thermostat...Rant [Re: autoxcuda] #354642
07/17/09 07:10 PM
07/17/09 07:10 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
best thermostat in the world won't work if you have air pockets.
I always used stant and had only one or 2 issues over the years. Would not consider Mr. Gasket since it's gotta be a reboxed off brand.
Re: Never buy a Mr Gasket thermostat...Rant [Re: RodStRace] #354643
07/17/09 07:22 PM
07/17/09 07:22 PM
San Antonio, TX
CurYellowBird Offline
San Antonio, TX
I run a 160* in my 80' malibu running a 350, mild cam, daily driver. It worked great for about 10k miles and then in town it would get around 180-190 and 210-220 on the highway. I'm considering just chucking the thing and drilling holes in a factory replacement. Other guys suggest to just run without a thermostat. Is this dangerous or is it pheesable?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Never buy a Mr Gasket thermostat...Rant [Re: CurYellowBird] #354644
07/17/09 08:39 PM
07/17/09 08:39 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Well since I first posted this I have replaced the Mr. Gasket stat with a 160*F Napa Special SuperStat. I bench tested all three and they begin opening at 165*F to 167*F. Eh...better than the Mr. G.....I also went ahead and drilled three 1/8" holes around the flange and popped it in, ran the motor, pulled the air bubbles out and finished off the mission. I also added in a 10" SPAL Pusher fan, and added a carb spacer to help reduce the heat from the engine. Havent gotten a chance to drive her yet as its still 95*F here and I dont wanna put her into that kinda stress. Maybe an evening stroll down the main blvd. in August.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Never buy a Mr Gasket thermostat...Rant [Re: Pyper70] #354645
07/17/09 09:31 PM
07/17/09 09:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I can't figure out why you all are having trouble with air pockets.
I have never drilled a stat, I have never had issues with air pockets. Not in an old car at least, had a few newer ones that had to have air released. But those have closed cooling systems.
Re: Never buy a Mr Gasket thermostat...Rant [Re: SomeCarGuy] #354646
07/17/09 09:36 PM
07/17/09 09:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Never buy a Mr Gasket thermostat...Rant [Re: autoxcuda] #354647
07/17/09 09:48 PM
07/17/09 09:48 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Milodon still carries the good ones for our older cars.
Re: Never buy a Mr Gasket thermostat...Rant [Re: Challenger 1] #354648
07/18/09 09:01 AM
07/18/09 09:01 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
same here,in 30 years ive never had air pocket issues.now gas issues are another thing
Re: Never buy a Mr Gasket thermostat...Rant [Re: mcmopars] #354649
07/18/09 02:13 PM
07/18/09 02:13 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Most stats if you look close at the contact area have a notch in them, probably for air or steam pockets that may happen under the stat.
