4 bbl carb conversion #353761
06/21/09 08:43 PM
06/21/09 08:43 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
I currently have a 273 2 bbl with auto trans. I have the factory 4bbl carb and manifold. If I switch to the 4 bbl, will my 2bbl carb and kickdown linkage work properly? Thanks.
Re: 4 bbl carb conversion [Re: 69fish] #353762
06/21/09 08:51 PM
06/21/09 08:51 PM
scratchnfotraction Offline
most likly you will need to make the rod from the bellcrank to the carb longer..about 1"-1 1/4" maybe
may need to slide the throttle cable a little forward in the clamp also
bouchillin has the best fitting and working cable throttle pressure valve linkage,IMO
just if ya want to upgrade from the 2-v linkage with a cable
