cam advance,blown,stroked
#352812
06/20/09 05:26 PM
06/20/09 05:26 PM
Posts: 42 Marshall, Texas
royt440
Marshall, Texas
CompCams XE268H-10 The following is from the spec card. I'm using 1.6 rockers: Intake .509, Exhaust .512 Duration @.006 I=268 E=280 Open @.006 I=28*BTDC E=74*BBDC Close@.006 I=60*ABDC E=26*ATDC These specs are for cam installed @106* Intake Centerline Duration @.050 I=224 E=230 Lobe Separation 110* Quote from CompCams instructions "We grind most all of our cams 4* advanced." So does that mean if I install it straight up (dot to 0* mark on crank gear) that I already have 4*? Do I need any more? The crank gear has settings for 0,2,4,6,&8* advance or retard. The block is a 440, .060over with the 500ci kit from 440Source. Stealth heads. Ross dished pistons. About 8:1 compression. Dyer's 671 blower, pulleys at 8lbs. Thanks, Roy
Re: cam advance,blown,stroked
[Re: blownzoom440]
#352816
06/20/09 11:47 PM
06/20/09 11:47 PM
DaytonaTurbo
Manitoba, Canada
the cam is small for the cubes but should be fun.
With a 6-71 on top that cam is tiny for the cubes. You're going to have so much bottom end with that cam you may want to retard it a few degrees for upper rpm help.
[Re: goldmember]
#352818
06/21/09 02:07 AM
06/21/09 02:07 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Sounds like a pretty mild build really, effective CR of about 10:1 maybe? Lots left on the table using a relatively small 6-71 on that much motor... Degree the cam in so YOU know what's going on and run it! ![](/ubbthreads/images/graemlins/Twocents.gif)
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: royt440]
#352819
06/21/09 07:25 AM
06/21/09 07:25 AM
royt440
Marshall, Texas
Again, Moparts members, thanks for the responses. It is going to be primarily a street car and I've always wanted a blower. There are quite a few nice 3rd gen Chargers in the Member's Photos. I already have a dial indicator and found some nine inch degree wheels on both Summitt and Jegs that aren't too expensive (for one job). I've printed the procedure from the links above and plan on giving it a shot. I had called the tech line for CompCams but must have called on their busiest day. ![](/ubbthreads/images/graemlins/shruggy.gif) Maybe I'll try one more time. Roy
[Re: royt440]
#352820
06/21/09 07:40 AM
06/21/09 07:40 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i know it is time consuming to check everything but you will relax knowing things are OK and where you can go from there.i have a .549/.559 113lsa,252/260* at .050 cam i ran for about 50 passes if you want to change.[solid lifter]cam only.40$ plus shipping.i went to a roller is why i changed it. what pulleys do you have?3%UD or 1/1?
[Re: blownzoom440]
#352821
06/21/09 09:41 AM
06/21/09 09:41 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Even with the small blower, I'd strongly advise checking with some cam guys about a real blower type cam. I dont think that one is what you want. I'm not the best with forced induction... but I think you may be better off with much more lift, at least 20° at .050, and an LSA around 114. And I wouldnt advance it...
[Re: Dodgem]
#352823
06/21/09 10:04 AM
06/21/09 10:04 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I have a nice roller for sale 114 lobe separation 268/270 @ .050 and .424 (lobe) lift =(.678 with 1.6)
[Re: Dodgem]
#352824
06/21/09 10:15 AM
06/21/09 10:15 AM
blownzoom440
ELYRIA,OH
I have a nice roller for sale 114 lobe separation 268/270 @ .050 and .424 lift =(.678 with 1.6)
not too streetable with the spring psi and the $$ of it.
[Re: blownzoom440]
#352825
06/21/09 11:16 AM
06/21/09 11:16 AM
R70RUNNER
Riverside, Ca
FWIW, one of the blower companies is now spec'ing 110lsa cams for street blowers, shorter duration with higher lift.Not sure if this is what the OP is using as a guide??? ![](/ubbthreads/images/graemlins/shruggy.gif) IMHO, the OP would be better off with a 114lsa, What he has will work, but he'll just lose some boost out the pipes. ![](/ubbthreads/images/graemlins/frog.gif) I'd call Engle Cams and see what they have to say ![](/ubbthreads/images/graemlins/Twocents.gif) ... ![](/ubbthreads/images/graemlins/laugh2.gif) Now if I can just get people to stop buying the blower(s) off my project motor it might get done too ![](/ubbthreads/images/graemlins/boogie.gif) Keep us updated Roy ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: blownzoom440]
#352826
06/21/09 12:30 PM
06/21/09 12:30 PM
Dodgem
Ontario, Canada
streetable is a wide perception! LOL!!! I know it's mild but he said he want's mild!
[Re: R70RUNNER]
#352827
06/21/09 03:52 PM
06/21/09 03:52 PM
blownzoom440
ELYRIA,OH
FWIW,What he has will work, but he'll just lose some boost out the pipes.
i dont think he will loose any out the pipes as it has 7* overlap.i ran it in my dynosim program for the cam profile. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Dodgem]
#352831
06/22/09 09:08 AM
06/22/09 09:08 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
how's a .424 lift cam got to 678 w/ 1.6's???? my math says it would bump to .452????
