thanks a million Rich,
I am running an Aluminum World Block (bushed)and planning to run:
.904 Crower solid rollers
Crower #33471 being:
LSA 108 + 263/268 @0.50 298/304adv + .625/.632
With Stage V replacement heads 2.25/1.94 ported to flow at least 400cfm @ .550+
11:1 comp 4.500 stroke 4.25 bore. 2 x 4bbl.
Milodon gear drive. Std cam dia.
Manual trans show car/limited street use.
Idle 1500rpm so should be some oil thrown around.
Deciding valve gear .. reckon Stage V will do but need to know if the World Block can be modified to pressure feed lifters..? The lifter bushings appear to have very small holes in them (pressure fed?)
Could I also use Smiths Bros p/rods + Jesel lifters?
Any help appreciated!
thanks again
