69 Charger headlight door ? #351894
06/19/09 02:41 PM
06/19/09 02:41 PM
Yocumtucky,PA
moparbo Offline OP
moparbo  Offline OP
Yocumtucky,PA
Hey gang. I recently acquired a 69 Charger and the light doors are up all the time. I noticed the "coffee" can is rusted and the two vac hoses that go to it are now attached. Is there any trick to get them to work or do I need a new vac can? A Charger looks cooler with the lights hidden. Thanks in advance!!!
There's no "I" in team..........but there's "ME"
Re: 69 Charger headlight door ? [Re: moparbo] #351895
06/19/09 03:46 PM
06/19/09 03:46 PM
Norway
General 68 Offline
General 68  Offline
Norway
You can make them work by running the vacuum line directly from manifold/carb, split it with a T and go straight to the actuators. I don't think you will be very happy without the canister as you might have to rev the engine to move the headlight doors. Might at least be a temperary fix.
