Wiper Motor Helop Needed #349478
06/16/09 09:24 PM
06/16/09 09:24 PM
NY, Monroe County
70RRJim Offline OP
70RRJim  Offline OP
NY, Monroe County
I have a couple of wiper motors out of b bodies in real good condition and wanted to pick the best one for my 70 road runner. I have both 2 & 3 speed motors.
-What is the best way to bench test the motors, connect 12volts / ?amps to what leads?
-Is there a difference in the wiper arm connectors to the motor pivot arm of a 2 or 3 speed.
Thanks in Advance
Re: Wiper Motor Helop Needed [Re: 70RRJim] #349479
06/17/09 12:30 AM
06/17/09 12:30 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The drive arm is different between them,and do not interchange, the shaft is much larger on the three speed motor.
The best way to check them that I have read is to plug it in the bulkhead connector and ground the motor and hit the switch...
