Thermoquad idling extremely rich **UPDATE**
#349418
06/16/09 09:17 PM
06/16/09 09:17 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
A week ago I swapped an Edlebrock 1406 for a factor 340 TQ (6139 I think) that I had just rebuilt. It was running great all weekend, then tonight the car started hard and when I did finally get it started it was running so rich it's puffing out black smoke. I took the top of the carb off, check the float height (brass floats), took the needles out inspected them and blew out the seats. I couldn't find anything wrong with it. I put it back together and it's still running rich like before. I'm not sure what to do next. ![](/ubbthreads/images/graemlins/shruggy.gif)
No longer taking $h!t from anyone!
Re: Thermoquad running rich
[Re: DUFFMAN]
#349419
06/16/09 09:46 PM
06/16/09 09:46 PM
DUFFMAN
Slantytown
I'll also mention that I did swap a 14" Edlebrock air cleaner for a factory drop door air cleaner last night. (I noticed it menation as a problem on Demonsizzler's site) but the rich condition continues even with the air cleaner removed.
[Re: DUFFMAN]
#349420
06/16/09 09:56 PM
06/16/09 09:56 PM
RapidRobert
Is the metering rod tree being pulled down at idle
[Re: DUFFMAN]
#349423
06/17/09 02:45 PM
06/17/09 02:45 PM
DUFFMAN
Slantytown
Here's what I'm thinking; the problem didn't start until I swapped air cleaners, so I must have bumped something in the process. The only 3 external things I can think of that would affect fuel metering are;
1. The metering rod tree. Which seems to be moving freely, but I will watch it with the engine running to make sure it pulls down.
2. Divorced choke. I can take measurements to make sure it is still adjusted properly.
3. Choke pull off. I'll hook a vacuum pump to it and make sure it's still working.
Anything else I should check?
[Re: 1_WILD_RT]
#349430
06/17/09 07:46 PM
06/17/09 07:46 PM
DUFFMAN
Slantytown
I originally used the square o-rings, when I took the top off I replaced them with the "X" style o-rings that Demonsizzler recommends using. No change with either style o-ring.
[Re: DUFFMAN]
#349431
06/17/09 08:55 PM
06/17/09 08:55 PM
RapidRobert
Dont give up on it yet it's gotta be something simple(it will be when you find it ![](/ubbthreads/images/graemlins/wink.gif) )especially since it happened suddenly. More thoughts: put the old aircleaner assy back on & see what happens. maybe the underside of the lid on the new one is too close to the vents but I wouldn't think it'd cause that kind of richness. I'm wondering if one of the wells in the phenolic body sprang a(slight) leak and when you had the top off neither of the floats were waterlogged? I would take the whole carb off & go over it w a fine tooth comb. You'll have a good laugh when you spot it.
Re: Thermoquad idling extremely rich
[Re: DUFFMAN]
#349432
06/17/09 08:59 PM
06/17/09 08:59 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
It's been a long time since I have had my hands in one. IIRC on the bottom of the bowl there are two smaller bakelite pieces glued to it to form a kind of V shape in one of the fuel passages. Those are bad to leak over time. When I was working on them we put something like JB Weld around those seams and also put a foam part from a Q-Jet in between the bottom of those V's and the base casting to keep upward pressure on the seam.
If those seams are leaky they would allow fuel to pour into the throttle bores between the bowl and the base casting.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: DUFFMAN]
#349435
06/17/09 09:19 PM
06/17/09 09:19 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Float bowl levels looked normal.
You'd never see a visable flaw in the wells, seperating the body while it still has fuel in it you should see a wet area.. Most experianced TQ guys just epoxy them as SOP...
[Re: astrobuf]
#349437
06/17/09 10:47 PM
06/17/09 10:47 PM
DUFFMAN
Slantytown
Well I got the Eddy bolted back up, but I didn't get it back on until after the kids went to bed so I'll have to wait until I get home from work tomorrow to fire it up.
