Make a 5.9 magnum into a 'crate motor'?
#348720
06/16/09 10:12 AM
06/16/09 10:12 AM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
What would it take to make a production 5.9 Magnum ('99 if it matters) into the equivalent of the 300 or 380hp crate motors?
My Durango will probably be retired next year, it's worth nothing on a trade - I would get more for it by selling the rebuilt 518 and the new tires on it than for the whole truck, basically giving me a stout, well maintained 5.9 for free.
Other than accessories, water pump etc., can I just change the intake and oil pan?
What else is different?
Thanks in advance
Re: Make a 5.9 magnum into a 'crate motor'?
[Re: YYZ]
#348721
06/16/09 10:18 AM
06/16/09 10:18 AM
Posts: 15,487 Florida
scratchnfotraction
cam swap and a carb intakeis all I seen thats diff from stock not sure on the piston though I would just swap in the 380 hp roller cam myself and call it done,IMO scratchin
[Re: scratchnfotraction]
#348722
06/16/09 10:59 AM
06/16/09 10:59 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
both engines used the truck pistons.
other than an LA timing cover, the only differences between a truck and a crate are the .525" lift springs and corresponding retainers, cam (380 horse) and intake.
personally, I'd probably use a comp XR265HR, eddie air gap, and springs to match (GM3100's & retainers if you can get enough IH, or hughes 1110's, etc)...should make similar peak power to the 380 horse crate motor, but with better low speed drivability and torque.
[Re: 70AARcuda]
#348726
06/16/09 05:34 PM
06/16/09 05:34 PM
Posts: 1,261 ILL
mark7171
ILL
[Re: mark7171]
#348727
06/16/09 06:35 PM
06/16/09 06:35 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
99 5.9 factory camshaft in 249 ex269 .410 .417 41 degrees overlap 99 318 factory cam shaft in 250 ex264 .432 .432 31 degrees overlap Mopar magazine did a ex test on the 300 hp crate motor and it made 300 hp with 318 ex manifolds and 325 or so with TTI headers, I would think a better cam and better intake could make 25 more hp
[Re: HotRodDave]
#348728
06/16/09 06:49 PM
06/16/09 06:49 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I wonder how accurate the published numbers are? I didn't know the 5.9 cam was ground on a 109lsa,the 5.2 with a 113lsa sounds right. I'm guessing it's like most MP cam specs,all over the place and rarley match any published info.LOL Yes the 5.9 stock with a rpm air gap or the knockoff and a set of headers should make the 300hp. Add a better cam and you can pick up plenty without giving up drivability. I helped a friend of mine with a cam swap and a set of R/T heads that I spent 1 hr with,makes 340hp at the tires and runs [Email]12.50@107mph[/Email] in a Dakota.In a 3100lb Abody with 4.10s it should find the 11's . No "quench" and runs fine on 87octane fuel.It's a 1996 engine I picked up out of a junkyard in 2001 that has never been touched.It will get a real set of headers and we'll ditch the single exhaust in the next phase.
