Any tuning ideas for a 318???? #348680
06/16/09 07:24 AM
06/16/09 07:24 AM
United States
tee-john Offline OP
tee-john  Offline OP
United States
I am a rookie at Mopar performance. Is there anything worth doing to a 318 to gain a lil more, or just cam it up a bit and exhaust. This project is just getting started. The car is a driver now and really needs nothing yet other than smokin tires. Thanks for help.
Re: Any tuning ideas for a 318???? [Re: tee-john] #348681
06/16/09 07:43 AM
06/16/09 07:43 AM
You might open up the dist & change the springs/shorten the curve/add initial and richen the carb jets(what year/carb type).You always want to attack the worst area 1st which would probably be the exhaust
Re: Any tuning ideas for a 318???? [Re: RapidRobert] #348682
06/16/09 09:10 AM
06/16/09 09:10 AM
Az
Crizila Offline
Crizila  Offline
Az
As usual, R&R is right on target!
Fastest 300
Re: Any tuning ideas for a 318???? [Re: Crizila] #348683
06/16/09 10:14 AM
06/16/09 10:14 AM
scratchnfotraction Offline
headers and duels
hotter spark
stock high stall verter from a /6
lower rear gear and short tires
small 4 barrel carb
small cam upgrade
lunati voodoo cams are good with comp 901-16 springs
360 heads and 188/160 valves, shave off .050 to keep some compression
run it down hill
maybe not that order,I start with gears and work forward
be surprized what a stock teen will do with just a gear change and buzzing it up in the rpms
scratchin
Re: Any tuning ideas for a 318???? [Re: scratchnfotraction] #348684
06/16/09 01:08 PM
06/16/09 01:08 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
A 4 speed with the 340's 290 hp cam is a match with 3.23 gears. 600cfm holley , factory vacuum HEI , headers.
Re: Any tuning ideas for a 318???? [Re: mark7171] #348685
06/16/09 01:11 PM
06/16/09 01:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
first steps: small 4bbl and dual exhaust
next: lunati voodoo 60400 and comp 901 springs.
after that: magnum heads
2017 Grand Cherokee Overland
Re: Any tuning ideas for a 318???? [Re: mark7171] #348686
06/16/09 03:02 PM
06/16/09 03:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
factory vacuum HEI
I forgot all about those!
