pinks seattle
#348572
06/16/09 12:22 AM
06/16/09 12:22 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
any one get there info packet yet??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: pinks seattle
[Re: superwrench]
#348574
06/16/09 01:15 AM
06/16/09 01:15 AM
Stroker Scamp
pacific northwest
Nope....but I killed the car on Sunday anyways.
Now the combination of money and time come into play!!!
you got enough time so break out the credit card, hate to do it but its a must,,,,,,,,,,,,what happened to the car??
Re: pinks seattle
[Re: toddd]
#348576
06/16/09 10:32 AM
06/16/09 10:32 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Don't know if the cam bolt came loose, or maybe the crank key let go.....I can't get the balancer off....Man it's tight! Anyways....a pile of bent valves on the left bank so far with #1 intake the worst along with a well bent pushrod. I'll get the right head off tonite...I suspect by the loose rockers that there'll be a few bent valves on that side too. One good thing anyways.....at least I had gotten thru the burnout and had throttled back when it died. I can't imagine the consequesences on a 6500 rpm shift!!! I'm gonna take some heat to the balancer and try to move it. It's a fluid one, so I'll possibly be looking for another one knowing my luck.
Re: pinks seattle
[Re: toddd]
#348578
06/17/09 12:53 AM
06/17/09 12:53 AM
superwrench
Bingo!!! The cam gear sheared off the dowel on the cam. I've got 9 bent valves and some hickeys on the pistons but nothing major. At least no holes!!! That'll teach me not to use a one bolt cam any more!! No pics...the camera somehow got put away so it wouldn't get lost. Now to start sourcing out some parts.
Re: pinks seattle
[Re: Jeepmon]
#348580
06/18/09 01:08 AM
06/18/09 01:08 AM
superwrench
Well I'll tell ya...I NEED some luck as of lately. Everything I touch either breaks, screws up or flat out don't work!! I decided to go back out to the shop tonite just to peruse the situation a little more and found something else I don't like..... #3 cam bearing seems to have worked it's way about 1/4" forward in the bore, and rotated about 180* so the oil hole is basically at the top of the bore. I know that can't be right as all the other bearings have the holes lined up at the bottoms. What in the hell woulda caused that? Looks like the whole things coming out now!! And I wanted to go fishing..... Don't worry...I'll get this thing back together in time for Pinks. That's a promise I'm keeping.
Re: pinks seattle
[Re: superwrench]
#348583
07/09/09 07:49 PM
07/09/09 07:49 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
We (the nearly 10 people i directly know going)still havent received anything either, so your not alone.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: pinks seattle
[Re: 452RT]
#348585
07/09/09 10:15 PM
07/09/09 10:15 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I got in but I'm having surgery on July 24th and looks like I need a driver for my car. I emailed the folks at Pinks to see if I can use a substitute driver.
Please let us know what they say.. I'm thinking they will say you're SOL as they told me they are cracking down on this type of stuff...
Re: pinks seattle
[Re: Jeepmon]
#348586
07/10/09 01:12 AM
07/10/09 01:12 AM
superwrench
One good thing anyways.....I got the "New" engine in the car and am just waiting on pushrods. They should be here tomorrow, then I can button it up and break it in. New cam, valves, bearings and some head work as well.That cam spinning out did a number on things. I hope to make a race on Sunday if my ducks all line up!! There's going to be a lot of little adjustments like jets etc, so I'm going to be a busy boy between qualifying rounds.
