2.2 degrees of pinion angle or 5.2? #347161
06/14/09 10:21 PM
06/14/09 10:21 PM
Out West
408strokerdart Offline OP
Out West
I have caltracs and mono leafs on the dart and was checking the pinion angle and I currently have 2.2 degrees nose down with a 3 degree angle shim. Those with caltrac experience, should I remove the angle shim to get 5.2 degrees or leave well enough alone? It is a crappy cast aluminum shim and I will eventually trade it out for a billet shim, but what do you think?
Re: 2.2 degrees of pinion angle or 5.2? [Re: 408strokerdart] #347162
06/14/09 10:33 PM
06/14/09 10:33 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
i would get some good steel shims and run it at your 2.2. calvert told me to run between 2-4 degrees noise down. I ran my 65 at 3 and never had a problem. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 2.2 degrees of pinion angle or 5.2? [Re: mopar65] #347163
06/14/09 10:39 PM
06/14/09 10:39 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
<---- still waiting to see Dart go down the track
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 2.2 degrees of pinion angle or 5.2? [Re: bigdad] #347164
06/14/09 10:43 PM
06/14/09 10:43 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
what is the tranny at
Mopar Performance
Re: 2.2 degrees of pinion angle or 5.2? [Re: moparniac] #347165
06/14/09 11:16 PM
06/14/09 11:16 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
where is the tranny at
fixed it
see small clip above
Re: 2.2 degrees of pinion angle or 5.2? [Re: 69B3GT] #347166
06/14/09 11:20 PM
06/14/09 11:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: 2.2 degrees of pinion angle or 5.2? [Re: moparniac] #347167
06/15/09 12:19 AM
06/15/09 12:19 AM
Out West
Out West
I don't know what the actual is, but the difference between the trans and diff is 2.2 degrees nose down right now with the car pretty level.
Re: 2.2 degrees of pinion angle or 5.2? [Re: 408strokerdart] #347168
06/15/09 01:41 AM
06/15/09 01:41 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
calling sixpakgut and quicktree .........
Re: 2.2 degrees of pinion angle or 5.2? [Re: 493_DART] #347169
06/15/09 11:47 AM
06/15/09 11:47 AM
Q
Quicktree Offline
Quicktree  Offline
Q
don't call me. call sixpack or calvert. sixpack is the TNT expert and calvert built them. I am thinking I would listen to calvert
