oil to topend on b1? #345701
06/13/09 12:51 PM
06/13/09 12:51 PM
KY
juicedcuda Offline OP
KY
My buddy just got his b1 motor back and is trying to prime the oil system with a drill and cannot get any oil to the heads. It is pushrod oiling, no spray bars in the valve covers yet. Any ideas what is going on?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: oil to topend on b1? [Re: juicedcuda] #345702
06/13/09 01:04 PM
06/13/09 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Roll the engine over with a breaker bar, the oiling
holes in the lifters might nnot be lining up...
hopefully the bushings were drilled in the lifter bores
Re: oil to topend on b1? [Re: MR_P_BODY] #345703
06/13/09 01:07 PM
06/13/09 01:07 PM
KY
KY
He said he knew they were drilled in the bushings. He also said he tried turning the motor over while using the drill as well?
Re: oil to topend on b1? [Re: juicedcuda] #345704
06/13/09 01:48 PM
06/13/09 01:48 PM
UK
602heavy Offline
602heavy  Offline
UK
Had a problem whereby no oil was getting to pas side rocker shaft , turned out the rocker shaft pedestal did'nt line up with the oil hole in block , the fix was to drill the pedestal out.
Spin the motor so #8 ex valve is just closing from fully open , this will line the cam bearing to oil way on pas bank , another 270* crank rotation will get the drivers side lined up , i found removing rocker shaft bolt will speed thing up regards oiling to heads.
Re: oil to topend on b1? [Re: juicedcuda] #345705
06/13/09 04:37 PM
06/13/09 04:37 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
this is what probably needs to be done!
Re: oil to topend on b1? [Re: boatracer572] #345706
06/13/09 05:06 PM
06/13/09 05:06 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The oil holes in the rocker shafts may not be in the correct spot. make sure they are pointing toward the pushrod. There is a little diagram at www.b1heads.com under the q&a then diagrams
Re: oil to topend on b1? [Re: joshking440] #345707
06/13/09 05:24 PM
06/13/09 05:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He's using pushrod oiling.... might have to notch
the lifter like shown above
Re: oil to topend on b1? [Re: juicedcuda] #345708
06/13/09 05:24 PM
06/13/09 05:24 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
stupid question but i assume it's building reasonable pressure at the back of the engine?
Re: oil to topend on b1? [Re: jamesc] #345709
06/14/09 11:33 AM
06/14/09 11:33 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Rocker adjustment bolt will not transfer oil to the rocker body if there more than 2 1/2 or more turns out.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: oil to topend on b1? [Re: go green] #345710
06/14/09 02:54 PM
06/14/09 02:54 PM
UK
602heavy Offline
602heavy  Offline
UK
I certainly would'nt rely on PR oiling alone , why block the oil feed off to the heads? , maybe restrict it yes , done more than my fair share of damage with spray bar oiling , those holes get blocked follwed by breakages , i run the indy heads but also had issues with the B1s.
Re: oil to topend on b1? [Re: 602heavy] #345711
06/14/09 04:05 PM
06/14/09 04:05 PM
jamesc Offline
jamesc  Offline
depending on what rocker assembly he's using they may not have provisions for oiling thru the shaft so PR oiling must be used.
Re: oil to topend on b1? [Re: 602heavy] #345712
06/14/09 07:37 PM
06/14/09 07:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would rather have push rod oil over shaft oiling JMO
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
