440 in a 68 Barracuda #345613
06/13/09 08:23 AM
06/13/09 08:23 AM
United States
tee-john Offline OP
tee-john  Offline OP
United States
is it a lot of trouble to fit a 440 in a 68 Barracuda?
Re: 440 in a 68 Barracuda [Re: tee-john] #345614
06/13/09 08:32 AM
06/13/09 08:32 AM
A fair amount which will be all but forgotten the 1st time you jump on it. Biggest obstacle is your exhaust choice. Probably $tti$
Re: 440 in a 68 Barracuda [Re: RapidRobert] #345615
06/13/09 10:30 AM
06/13/09 10:30 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
check out bigblockdart.com
Re: 440 in a 68 Barracuda [Re: RapidRobert] #345616
06/14/09 07:42 AM
06/14/09 07:42 AM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Thanks for the info. I am a first timer with wanting to do an engine swap so I don't know which would be a better choice or a not too difficult choice. 440 or try to find a 383. This car is a 318 so it needs a lil something. Thanks again.
Re: 440 in a 68 Barracuda [Re: tee-john] #345617
06/14/09 08:34 AM
06/14/09 08:34 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
One of the B engine strokers (400 based engines) will give you a bit more room. worked out better in my early A body.
Re: 440 in a 68 Barracuda [Re: Maximus_Wedges] #345618
06/14/09 10:15 PM
06/14/09 10:15 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There are different fitment issues with a "B" block and an "RB", but both fit reasonably well and can be made to run really well. Spend some time in the tech pages at www.bigblockdart.com.
Re: 440 in a 68 Barracuda [Re: Maximus_Wedges] #345619
06/14/09 10:17 PM
06/14/09 10:17 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Thanks, I will look at that.
Re: 440 in a 68 Barracuda [Re: Jim_Lusk] #345620
06/14/09 10:23 PM
06/14/09 10:23 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Thanks for the link.
