clear-coating pot metal? #344946
06/12/09 02:13 PM
06/12/09 02:13 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I just wire-wheeled my rear-view mirror bracket last night, and I realize it's pot metal and want to make sure it stays looking new, but in the same color. Would anyone clear-coat it to keep it looking good, or is there something else? If you use clear-coat, which do you use? I kind of want to keep the same amount of shine too, not too shiny, not to dull. Thanks for your help!
Re: clear-coating pot metal? [Re: sharpie] #344947
06/16/09 03:20 PM
06/16/09 03:20 PM
You should get decent results from a gloss clear coat spray. Just make sure you degrease the melt real good before you spray it.
Re: clear-coating pot metal? [Re: sharpie] #344948
06/16/09 10:08 PM
06/16/09 10:08 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have had great results using Minwax polyurethane clear in a spray can.Comes in satin,gloss and semi gloss finishes.
Nautilus Racing-
