a-body and pistol grips #342285
06/09/09 06:02 PM
06/09/09 06:02 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
Could a-bodys ( 70-up) have a pistol grip from the factory if equipped with the 4 speed .
If ,so, was it only Duster and Demon or could the darts also have them
thanks
Re: a-body and pistol grips [Re: mxbeep] #342286
06/09/09 06:12 PM
06/09/09 06:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No
Re: a-body and pistol grips [Re: DAYCLONA] #342287
06/09/09 06:46 PM
06/09/09 06:46 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, no console 4 speeds after 1969 either
Re: a-body and pistol grips [Re: mxbeep] #342288
06/10/09 12:40 AM
06/10/09 12:40 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
No.
If you are going to put a PG handle in an A body, use the 71-74 B body non-console stick.
Re: a-body and pistol grips [Re: ScottSmith_Harms] #342289
06/10/09 10:44 AM
06/10/09 10:44 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
As said above, no P Grips in A-body's from the factory. I have seen a proto-type that was never used however.
From factory parts books (shift handle part #):
#2950055 68-9 Hurst Console A-body (Press-In)
#2996314 70 Hurst Console A-body (Press-In)
#3467736 71? 72-3 Hurst Console A-body (Bolt-On)
I have had all 3 different ones, 68-9 are bent slightly different than the 70-3. 68 uses different font on the “HURST” than the 69-Up even though they carry the same part #.
