Rule of Thumb-> Re-torque Mains
#342140
06/09/09 12:34 PM
06/09/09 12:34 PM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
Guys!
I just pulled my 340 in order to replace the rear seal. And the question came up, should I inspect and/or re-torque all of the mains (or just the rear main)?
Or "if it ain't broke", "don't fix it"...
Anyone?
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Rule of Thumb-> Re-torque Mains
[Re: cuda_tim]
#342142
06/09/09 03:02 PM
06/09/09 03:02 PM
RapidRobert
With the eng being out yes pull the caps & eyeball the bearings. A basic visual inspection uncovers alot of problems(or in this case will let you sleep better at night knowing that everything is fine)
[Re: RapidRobert]
#342143
06/09/09 07:50 PM
06/09/09 07:50 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Fresh motor? High mileage? Noisy? If the rear main seal leak is your only problem, fix it and go.
[Re: cuda_tim]
#342145
06/12/09 11:57 AM
06/12/09 11:57 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If there was a problem due to torque you would have seen it already. I'm a big fan of not disturbing things that dont need it so I'd just leave well enough alone and fix the seal.
