Dash light dimmer switch failure? #34178
01/22/07 02:43 AM
01/22/07 02:43 AM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I just got my 68 Coronet back on the road and realized I never tackled a problem that occured this summer: I have no dash lights. I traced the problem to the dimmer switch. The main light switch sends power to the dimmer switch, but I have no power from the dimmer switch at the instr light fuse. Is the dimmer going bad a common thing? Or is there something I could be overlooking. If it helps, the console/dome lights work, but the dimmer doesn't dim them (although I dunno if it's supposed to).
"Broke is temporary, cheap lasts forever"
Re: Dash light dimmer switch failure? [Re: 68Bullet] #34179
01/22/07 08:49 AM
01/22/07 08:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes the dimmer going bad is common , good used or NO$ is the only options , the resistor wire coil opens eventually .
best way to confirm is to put it to the full bright position with the lights on , if you get lights its the switch .
you confirmed the guage assembly is grounded well ?
Re: Dash light dimmer switch failure? [Re: JohnRR] #34180
01/22/07 01:13 PM
01/22/07 01:13 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
hmmm, no matter where i rotate the dimmer switch i get no instrument lights. i was thinking of jumping the connector to 'bypass' the dimmer. As a test or otherwise. Bad idea?
Re: Dash light dimmer switch failure? [Re: 68Bullet] #34181
01/22/07 01:56 PM
01/22/07 01:56 PM
central New Jersey
dbdartman Offline
dbdartman  Offline
central New Jersey
Good idea & likely the most common "low buck" fix there is. This won't hurt a thing.
Re: Dash light dimmer switch failure? [Re: 68Bullet] #34182
01/22/07 04:10 PM
01/22/07 04:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The rheostadt (variable resistor) is dirty or broken in continuity.. Pull off the 3 terminal connector and jumper the 2 orange wires using a short wire lead with male tab 0.25" terminals. Now you will get the full 12V to the dash lites. The other terminal is for the Dome lite, and you should run a short lead back the switch for this.
For the Dome lite circuit to work rite the dash ground circuit must be tite and secure.
Note that for the dash lites the only question about grounding is the bulb socket itself on the circuit board. Make sure the circuit board has a good solid ground, as there is no grounding through the dimmer switch for the dash lites. Its purpose is to reduce the 12V down to 5V and this is done on the 12V+ side which is above ground..
The single wire is for the Dome lite circuit.
Hope that helps...
Re: Dash light dimmer switch failure? [Re: 68Bullet] #34183
01/22/07 07:45 PM
01/22/07 07:45 PM
California
mickm Offline
mickm  Offline
California
guy named rich sells these, i think he rebuilds them. i'm looking for one for my 70 RR. he has one but says it has a little bubbling on the chrome, probably not noticable when installed. i'm waiting for a better one. he contacted me here on the board after i posted a similar question. his email is runnernest@yahoo.com.
mickm
