rear suspension bump #339259
06/06/09 01:11 AM
06/06/09 01:11 AM
central Kentucky
moprod Offline OP
moprod  Offline OP
central Kentucky
My rod has a great ride, until you hit a bump or rut in the road.
Smooth quiet ride on good roads, sounds terrible when you hit a bump.
It has leaf springs and new shocks. Would those helper springs on the shocks help? never used them before.
[img] [/img]
Re: rear suspension bump [Re: moprod] #339260
06/06/09 01:22 AM
06/06/09 01:22 AM
Wildomar CA
moplumber Offline
moplumber  Offline
Wildomar CA
Are the leafs stock ?
Re: rear suspension bump [Re: moplumber] #339261
06/06/09 01:55 AM
06/06/09 01:55 AM
central Kentucky
moprod Offline OP
moprod  Offline OP
central Kentucky
yes, they are factory. To be honest I feel pretty sure they were checked out when the car was being built.
I did remove a leaf a couple of years ago because the car sat too high. This thing had 10 leafs in each spring.
[img] [/img]
Re: rear suspension bump [Re: moprod] #339262
06/06/09 04:28 AM
06/06/09 04:28 AM
Wildomar CA
moplumber Offline
moplumber  Offline
Wildomar CA
I would check for for a broken leaf? after 70 years of movement the springs are now flexing more or a bushing may be binding ? Thats where i would start.
I have a 37 dodge 4door and im gonna use toyota pu leaf assembly. any minitruck springs will work and can be bought cheap. And is an easy way to update your suspension
Re: rear suspension bump [Re: moplumber] #339263
06/07/09 10:12 PM
06/07/09 10:12 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is your problem a suspension problem, or a body to frame or fenders to body issue? Lots of stuff to go different directions then come back together after a bump back there. Gene
Re: rear suspension bump [Re: poorboy] #339264
06/08/09 12:51 PM
06/08/09 12:51 PM
central Kentucky
moprod Offline OP
moprod  Offline OP
central Kentucky
I will get it on a rack and chek things out , again. Some good points ,thanks.
[img] [/img]
